Question about Twinhead DURABOOK N15RB Notebook
Durabook laptop The laptop doesn't come up at all. Wiped hard drive afterwards because didn't need data. Now trying to reinstall OS. Won't boot from CD. Can't get to CMOS setup long enough to change boot sequence; shuts down. Not that good with laptops. Willing to try. CMOS battery, Motherboard????? Can't seem to find a troubleshooting website for durabook.
How do you repair a lapptops wiped hard drive
reformat it and reinstall the operating system via the cd slot
on start up hold down the alt,ctrl, and delete buttons to get into the bios the select boot from cd
once the os is in then close down and open it again and do the 3 button entry to bios again and change the selection to hard drive for boot up
you will have to re enter all folders and programs as a wiped or formatted HD is clean to start with
Mar 01, 2016 | Toshiba Satellite Computers & Internet
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
Stop error on sony vaio vgn-nw235f
There are multiple possible reasons for your problem:
1. virus
2. hard-drive malfunctions
3. OS malfunctions
4. memory failure
Try to install an antivirus and do a deep scan. You should pay attention to a boot sector virus.
If this doesn't help, do a back-up of your data, format your hard disk and re-install a fresh OS.
If this doesn't help either, try changing the RAM memory.
If that doesn't help either, it means your hard disk's boot sector is damaged. There are solutions for this too, but I think there is a big chance you won't get to this point.
Aug 07, 2012 | Sony NW Series VAIO VGN-NW235F PC Notebook
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Unmountable boot disk error on blue screen
first, recover your files. You will need to use some data recovery program like asoftech data recovery. you can download it from
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 07, 2011 | Gateway Computers & Internet
When i turn my acer aspire one d255 netbook on it says no bootable device -- please restart system i need help please
It looks as though the laptop is not recognising the hard drive, there is no hard drive fitted or there is a hard drive but the OS boot record has been wiped ( I know this sounds obvious but some people buy these 2nd hand only to find the hard drive was removed)
You need to check the hard drive is present by booting to the bios screen it should "see" the hard drive attached. If it is present, then you have a problem with the OS or a damaged hard drive. I think its DEL or F2 or F10 to access the bios, not certain.
At this point, you need to attempt to reinstall the OS, as this does not have an optical drive, you will need to obtain a USB Optical drive, go into the bios and see that it is recognised as a boot device. Do not worry about setting the boot order, the Bios will locate the rom as a boot device.
Attempt a start up repair, ie: wait until the installer looks for a previous installation of windows (if one exists) then allow it to install a repair installation. If it does NOT find this, you will need to doa full install. If at this point you have files you need recovering, a strip down of the netbook and removal of the hard drive will be necessary. You simply then get someone with a computer to jumper your hard drive as a slave and recover the files you need, as a full install requires the hard drive to be fully wiped.
Replace the hard drive after you have done this and proceed with the full reinstall
You can use a USB boot device, but to do this you will need to have access to another computer to make the boot installer:
Aug 02, 2011 | Acer Aspire One D255-2670
Os not found
when you first switch on, look for boot options and select it, may be F8 or esc, when you see the boot list, select the one that looks like a hard drive, you may only be able to tell because its none of the other options. If there is not a drive too boot from or all options fail, have a look at the bottom of the laptop for a removeable panel, there may be more than one. There will be one which gives you access to the hard drive itself, check that the drive is securely connected, maybe worth taking the drive out just to put it back in again, then try booting the machine again, may need to go through the boot options again to select the drive
May 03, 2011 | Lenovo 3000 N500 Notebook
Black screen on Vista reinstall
make sure you have only one video card installed check bios for the video card.. try vga..if expansion video card is installed...remove it and use the internal to check if it works..
Dec 30, 2009 | Microsoft Computers & Internet
Boot problem
If you repair the os using the cd, The personal files will remain as is.But if you format the drive and reinstall the os then everything is wiped out. Try repairing the os, If not then log on using the safe mode and copy your data on to a different drive. Or use a floppy to log through dos mode and back up your data
Feb 01, 2009 | Toshiba Satellite M45-S165 Notebook
I've tried to reboot my daughters laptop. It is vista. I held down f8 and tried several of the repairs but nothing has made it work. I tried starting it in safe mode but it just stops. Is there anything...
You should download UBCD4Win and try booting from the UBCD4Win CD/DVDto recover your files. Since you said you've tried booting into Safe Mode but it didn't work, from my experience, most probably the OS is corrupted. Try using UBCD4Win to recover your files to a USB drive first and then reformat the hard drive and reinstall Vista. Hope that works for you. Good luck
Dec 26, 2008 | Computers & Internet
Twinhead DURABOOK N15RB Notebook Logo
318 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
