Question about Samsung Prostar DCS Phone
Need Tech. Prog. Passcode
I needed to add some of our phone lines to recieve group calls, but it says they are not group members, so now I need to add members to the group. I believe I found the information on how to do that, but after dialing TRSF 800, the "ENABLE TECH.PROG PASSCODE" message appears and everything I try is invalid, like '4321' or '1234' or '0000' or anything like that. Nobody knows what this passcode is, as most people in this company have left us. Please, if there is any way to reset this password, let me know how, our phones depend on it! Thanks in advance!
  • 24 Answers
Some one has changed the pass code from the default value, the kiss of death as far as I'm concerned. Try the ADMIN option by pressing TRNF 200 and use pass code 1234, The programs you can change in that section is limited but you may be able to get to Program 601(the one you need) by using the ADMIN access. If that won't do it. You will have to get a Samsung Tech to default your system and reprogram back with the default codes.
Good luck
Posted on Dec 28, 2008
Hi I have a Panasonic KX-T7667 Telephone and it rings for intercom calls, but for external line calls it won't ring, I just get the flashing lights for the phone line. I have tried the volume...
Solid lights mean it's not programmed in the ICD group. Depending on the issue of your system cabinet, ICD ring group pilot numbers begin with 600 or 601 and grow to as many as you need. Each phone that rings has to be a member of the group and you can program it to not ring, ring immediately, or a delay of up to 6 rings. In my office system ICD group members are assigned in system program 620.and the ringing is programmed in 621. It's not entirely friendly to change it by hand as the tables are assigned by group and position, but it can be done.
It's an installer function and requires the system password or permission to change it.
Carl
Jun 19, 2011 | Lands Phones
How do I turn the ringer on the phone. We have 5 phones in the office and only one rings. Is there a way to turn a ringer on all 5 phones so we can hear incoming calls from all offices?
Hi, you need your main telephone number to ring at a group ie 500, then you need to add the extensions to that group, I will try to explain;
With your handset down press TRANSFER - 200 - 1234 - 1 - SPEAKER KEY
Then dial 714, use the volume key to find the phone number required, the using the 3rd little soft key under the screen find the 1 or DAY destination type in the group number .
Then press speaker and go to 601 and add the members to the chosen group, I have uploaded a video explaining how to do this step. Go to http://www.abbeytelecom.com for more training and programming tips.
May 17, 2011 | Samsung Prostar DCS Phone
How to reprogram so that incoming calls ring on all phones, not just the main phone.
Hi, this can be done at customer level programming, first add all extensions that you want to ring into a group ie 500, this is done in MMC 600, add them as members. Once you have done this you need to go to MMc 714 and set the group you have chosen as the destination corresponding to that incoming phone number. I have uploaded a video which hopefully will help - please visit www.abbeytelecom.com for written instruction.
Dec 14, 2010 | Samsung Prostar 816 Phone
Need to make a new phone ring
Go to GROUP Incoming Call Distribution (probably Group 1 for 300) and add your extension as a member of the group.
Carl
Aug 31, 2009 | Panasonic KX-TDA50 Phone
Turn off Ringer For External Calls Only
If you use strata emanager it would depend on how your system was set up. One way is to go to Advanced configuration tab Station tab, multiple call group tab, click on the group number (far right), then member tab and select extention and ringing option. Another way is to go again from the advance configuration tab, then assignment tab select the extention number on the right select key assignment tab, and on the incoming extention line double click it nd select no ring.
Jun 11, 2009 | Toshiba DKT3020SD Corded Phone
I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
Mar 23, 2009 | Panasonic KX-T7633 Corded Phone
I need a manual for a blackberry 8700 c
You should be able to do this by going into contacts, hit the menu button, then choose Add New Group, enter a name for the group, then hit the menu key again. Choose Add Member, and select the people you want in your list!
By the way, you have to have the people already saved in the phone to add them to a group.
Hope this helps!
Justin
Oct 29, 2008 | RIM BlackBerry 8700c Cellular Phone
Programming button on kx-t7633
Sure, the magic number you're looking for is 30.
Press PROG the button, dial 30 601 ENTER and you'll get what you had.
Carl
Jul 18, 2008 | Panasonic KX-T7633 Corded Phone
Ringer for incoming outline call??
Those settings are in the Incoming Call Distribution Group. Just add the phones you want to ring to the Members of the appropriate group.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Jul 02, 2008 | Panasonic KX-T7633 Corded Phone
Samsung Prostar DCS Phone Logo
233 people viewed this question
Top Samsung Lands Phones Experts
Don Hart
Jose Ma DM.
Jose Ma DM.
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
