Diplomat 8512 Washing machine - water spilling out of detergent tray? Here's hoping for a simple solution.... When I start any program the water fills up the drum and then starts to pour out of the detergent tray (*Which seems to close fine). The machine is built into the units and seems level. The spin works fine & the filter is clear. Any help would be appreciated!
  • Anonymous Mar 19, 2014
    Drum fails to turn sometimes during operation, it is not overloaded
  • 135 Answers
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
Posted on Nov 07, 2008
Does anybody know where is the pressure bottle located on a diplomat 8512 washing mahine
Posted on Jan 31, 2010
Detergent not completely dissolving and small amount of water on the floor
Check detergent is properly inserted. if the tray is not fully in detergent will not dissolve and also water will spill. OR the water pipe may have pushed back.
Dec 08, 2016 | AEG Washing Machines
Why My Samsung wahing machin is spilling water FROM the detergent box
This can happen if your water presuure is too high. The water can splash over the top before going into the drum. Or the channel is blocked and needs clearing. Usualy a simple job
Oct 03, 2014 | Samsung Washing Machines
Maytag neptune frontloading washer overflow
If you cannot clear the line, you will need to replace it. Here is the line to order.
Nov 22, 2012 | Washing Machines
Where to put soap powder in Diplomat 8512. There are three compartments in the dispenser drawer.
it goes in the iddle one, the right hand one is for softner and the left is for pre-wash. hope this helps.
cheers
iain
May 03, 2011 | Washing Machines
Detergent dispenser is filling with water and water is running out of the dispenser. cannot see anything wrong , cracked or missing o-ring
Remove the dispenser tray from the machine and clean the exit passage if plugged with washing compounds. Use a liquid detergent if you are not already doing so. If the tray looks ok, you may have excess water pressure which might be forcing more water flow than the tray can handle. Another respondent suggested turning the supply faucets down somewhat to reduce the amount of water coming into the machine. If you have your own well, the system water pressure can be turned down at the pump control (about 35 to 40 PSI is about right). Hope this helps!
Aug 07, 2010 | Samsung WF328AA Front Load Washer
Water is coming outof the detergent/conditioner
is the machine still filling may be as simple as to much water pressure turn the tap down a little
Mar 29, 2010 | Washing Machines
After washing clothes, water stays in the detergent tray.
Best plan is probably to take the detergent tray right out of the machine, then take it to bits before washing it out with hot running water and a toothbrush.
The problem with these things is that the bit that blocks up is pretty well hidden until you dismantle the tray.
A.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
SIEMENS XLM 1600 (WXLM166AGB) MACHINE WILL NOT TAKE IN SOFTENER FROM DETERGENT TRAY
If water is being dispensed from both sides of the detergent tray, dismantle washing machine and remove top plate of the detergent tray and clean thoroughly. Water overflows from both sides during the rinse cycle to add softener to the rinse. On our washing machine it was blocked. During the service it was changed but can be washed out to solve problem.
Aug 28, 2008 | Washing Machines
Water in detergent dispenser
I think this is normal. Mine does too.
Jun 21, 2008 | LG WM2688H Front Load Washer
Detergent tray has too much water @ end of cycle...
Try pulling out the tray gently. Your tray is clogged with detergent which you have to remove with a tooth brush or something.....minor problem u have.
Sep 27, 2007 | LG WM2277 XL Front Load Stackable Washing...
Washing Machines Logo
692 people viewed this question
Top Washing Machines Experts
