Question about Cameras
Memory card I bought a Delkin 8GB memory card and when I tried it on my camera (Fuji S2) it shows: Card not initialized. it will not fomrat it because it will accuse card error. And the reader (Lexar) will blink its llight (so it is reading the card) but it will not show up on my computer!!! What can I do?
  • 48 Answers
From what i can find the Fuji S2 DSLR can only take up to a 2gb card, so this would explain card error the camera cannot register the space available.
I am getting more problems like this the card manufactures bringing out these large high speed cards, but only the newer cameras can use them, the older ones just show an error.
Similar problem with the computer especially if you have bought one of the new udma cards (305x speed) your computer or card reader might be letting you down. Have you tried formating the card in the computer and then writing a file to it, this will determine if there is a fault with the card.
Posted on Nov 17, 2008
Error message card not initialized. It's been formated, and new batteries installed. what is the next thing to try?
Sounds like you pulled the card out while it was still uploading images to the computer, corrupting the card. So...a.- to try to recover the photos, you'll need photo recovery software, like digital photo rescue or others available via an internet search and...
b.- you'll need to put the card into the reader after you're done and reformat in FAT (not FAT32, not NTFS) so the card will be readable again in the S2pro.
What would happen is this: people would attach the card to the computer and delete using the computer. This can create a recycle bin on the drive. The next thing is that the card might be "unmounted," in that many people will just pull the memory card out of the reader and stick it into the camera without first unmounting the card.
This leave the card in an "open" state which the S2 Pro cannot properly read. The solutions:
1.- make sure there's no recycle bin on the card;
2.- plug it into your computer, and then properly unmount the drive using the taskbar, then pull the card out of the reader after you've been told it's safe to remove the card.
Since you describe a power issue as a possible initial cause, your final option is a new memory card. Also, only format in FAT format, since that's what the S2 Pro can see; not FAT32. You might also try formatting in another camera and then the S2 Pro.
Hope helps.
May 23, 2011 | Fuji FinePix S2 Pro Digital Camera
Fuji s2 will not except 8 gig compact card, but is fine with a 3 gig
With how old that camera is it's not able to recognize all 8GB of the memory card, it will recognize, at most, a 4GB card which means you need 4GB or smaller compact flash cards.
May 11, 2011 | Cameras
Fuji FinePix S2 Pro New 4 Gb disk in cam prompts msg ''Card not initialzied.'' Have tried many things. None work. Help.
Go into menu and try to format memory card. Most cameras can just use card right from package without format.Formatting will delete all pics if any available. This is the only solution for your problem.
This is the procedure,In playback mode on the camera (green arrow on selector switch - or middle option if the legend has worn off) press menu/ok -> select format -> menu/ok ->menu/ok to confirm
Any pictures on the card will be lost.
Thank you !!
Jun 25, 2010 | Fuji FinePix S2 Pro Digital Camera
Have a Finepix S602Zoom which on warning display now shows ''Card not initialised''- have bought a new 4GB card- but still have the same problem.. Any ideas - software prob?
This is a common error in the FinePix product range. When you receive a "Card Error" or "Card Not Initialized" message, this indicates that your camera's memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most users will use the "delete all" feature and continue to take pictures but by doing this the file format of the card may become unstable and unusable.
Fuji recommends formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted the images will not be recoverable. So format the current cards and they should be useable again.
Sep 25, 2009 | Fuji FinePix S7000 Digital Camera
Memory card error in 8GB card
Try to re-insert the card. If that doesn't help try to reformat it/delete all its contents. Also check in the manual what kinds of cards does the camera generally work with (although i doubt that is the problem).
Dec 23, 2008 | Canon PowerShot S2 IS Digital Camera
Memory card
Because this camera only understads FAT16 formatting, it does not accept any card larger than 2GB so your best bet is to use the current crop of standard 2GB CF cards, most newer ones (usually 16X and faster) are alsa fast enough for continuous VGA video as well. The best brands IMO are Lexar and Sandisk, but avoid the WA enabled cards, this camera can't make use of WA, it just slows the througput down.
Alternatively you may partition your 8GB card to a 2GB partition, but the rest of the card won't be accessible.
Aug 28, 2008 | Fuji FinePix S602 Zoom Digital Camera
Memory card not initialized
You just need to reformat the card, which you can do through the camera.  I sometimes get this problem with my memory card when I take it out of my card reader without properly ejecting it first.  The camera will say something along the lines of "Card Not Initialized".  So, turn on your camera, hit "menu", then go to "option" (and subset "set up") , then "format" and go to the right and then click on OK and if I remember correctly, it will ask whether you really want to reformat, which you do.  Caution though---you will lose any pictures on your card by doing this.  But it should solve your problem!  Good luck!
Mar 20, 2008 | Fuji FinePix S3100 Digital Camera
Fuji S2 pro, LCD screen flashes up write error.
It could be a faulty memory card. Or maybe dirty contacts on the card itself. Try swapping cards with a friend or your local camera shop and see if it works then. Maked sure the card is correctly inserted too. If the card formatted in the camera it should be OK. If it was corrupt it would show up during format. I hope you didn't buy the card off Ebay through an Asian or Chinese dealer. They are conning people with half a gbyte card marked as one gbyte. Some of them are reworked so they show the full Gbyte but when you go to format them they crash when you try to use them. Anyway it should be under warranty so ask for an exchange or even a different brand. BMW
May 31, 2006 | Fuji FinePix S2 Pro Digital Camera
Cameras Logo
110 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
