Question about Nikon Coolpix 3200 Digital Camera
Lens is not opening in the movie mode,unable to record movie also.
When I switch on the camera in the movie mode, there is a warning which says 'mode dial not in proper position'. The camera doesnt open, but it opens with the setup and scene. There is no beep sound when i change to the movie mode from the setup mode or other modes. But, the mode is activated. Also when i try to record a movie in this, it doesnt, I am only able to shoot an image. The menu is also only for image. It doesnt display the movie menu. Kindly help. Very urgent. Thanks.
  • Nraja Appan Nov 01, 2006
    Thanks.
  • 188 Answers
Normally there are two possible causes for the problem, 1) the connectors of the rotary switch are dirty or not making proper contact. 2) the cable from the rotary switch is damaged. In both the cases you have to get the swith changed.
Posted on Nov 02, 2006
SOURCE:
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Jan 24, 2016 | Canon PowerShot S3 IS Digital Camera
Sony dsc-H1 won't switch off of movie mode
When you switch the camera from mode to mode, does it make the click noise to signify that the camera recognized that it changed modes? If not it could be that the switch itself has become unlogged from the switch. I know I had a older camera had this happen before. Try pushing down hard on the toggle wheel and seeing if it will snap back into place. Otherwise the switch inside the camera itself is probably broken, and if this is the case cheapest thing you can do is have Sony do warranty work on the camera. http://www.sonystyle.com/webapp/wcs/stores/servlet/SYCustomerCare?storeId=10151&catalogId=10551&langId=-1 Click repair and service under Technical Support. This will get the process started on the warranty work.
Aug 25, 2007 | Sony Cyber-Shot DSC-H1 Digital Camera
Display dead in most, but nbot all functions
While a cable is connected to many Nikon cameras the screen shuts down.
Sep 22, 2017 | Nikon COOLPIX Cameras
Display dead on most functions, but not all
The display is ALWAYS dead as long as a cable is attached. To make it work again disconnect the came and cycle power on the camera.
Sep 21, 2017 | Nikon COOLPIX L820 Digital Camera Black
How to i use video mode
Rotate the Live View switch to the LV position. Focus by pressing the shutter release button halfway. Start recording by pressing the movie-record button. Stop recording by pressing the movie-record button again.
Full details are in the "Recording and Viewing Movies" section of the manual (page 107 in my copy). If you need a manual, you may download a copy here.
Jun 09, 2012 | Nikon D5100 Digital Camera with 1855mm...
Camera does not work in record mode
the problem coming from ccd image sensor . u must to chaing that part
Aug 21, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Video
Lizzie,
This may sound like a dumb question, but are you sure that you had the camera set to the video recording mode? Several of the Canon digital PowerShots will show the movie icon on the LCD screen even when the camera is in image record mode. Why, I don't know. Ensure that you set the camera into movie mode by pressing your Func/Set button to go into the Function Menu and then selecting the movie mode that you want to shoot in. Press the Func/Set button again to get out of the Function Menu and you will not only see a movie camera icon on the LCD screen, but also a set of numbers in the bottom left hand corner representing the recording resolution (e.g. 640 pixels) and the frames per second (e.g. 30).
And just in case you did have the camera set in movie mode, make sure that you don't do what many people have inadvertantly done and mistake the video clip for a .jpg image in the playback screen. Videos will of course have the movie camera icon in the upper corner of the image and are viewed by pressing the Set button twice to begin the playback.
If both of these steps were performed properly then your camera may have a hardware issue. As a last resort, try performing a reset from within the menu just to be on the safe side and see if it makes a difference. If not you may need service. Hope this helps.
Sincerely,
HeavyDLB
May 26, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
A345 stuck in movie mode
you need to open the camera caseing a small amount. As you put the case back make sure the switch is in the movie position so it will engage the switch inside on the circuit board. Looks like the switch has been knocked off the control inside.If you have been moveing the switch back and forward you may have broken it.
Dec 27, 2006 | Fuji FinePix A345 Digital Camera
UNIQUE PROBLEM: Camera stuck on Movie mode
It's a small world. I have an Ixus V2 on the bench with exactly the same problem. The sliding button on the camera mates with a switch soldered to a flat ribbon cable inside the camera. There are two small teeth which move the internal switch left ot right. What's happened is one of those plastic teeth has snapped off the external part and now it can't push the switch anywhere. If you pulled the camera apart you could push the switch into either record or review but that's it. It will stay in either of those positions. Which is a bummer. The only way to fix it is to buy the complete flat cable ribbon with switch attached and boy it's a long cable. Except for sending it away for repairs (expensive) buy a damaged one on Ebay and do a transplant. Just make sure it's suffering the same fault.
Jul 19, 2006 | Canon PowerShot SD300 / IXUS 40 Digital...
Nikon Coolpix 3200 Digital Camera Logo
150 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
