My son inherited an UltraRacer controller for his PS2, but there are no instructions on how to program or reset the controller to defaults, and it does not appear to be recognized by the PS2. Any help is appreciated
-   Iam also having problems programming my UltraRacer Control for my new Playstation2. i don't need to relocate, I just need to get it programed. my New PS2 seems to not be reading my controller. -   benavidezant
Here's the instructions on how to relocate buttons:
1. To assign one button (i.e. "R") to perform another buttom function (i.e. "Z"): Press and hold the SET button for about 1 second to enter the "FUNCTION SETUP MODE", the FUNCTION SETUP LED will illuminate and two beeps will be heard.
2. Press the button (i.e. "R") you would like to reassign one time, the FUNCTION SETUP LED will blink once and a single beep will be heard.
3. Press the new, desired function (i.e. "Z") one tim, the NORMAL LED indicator will illuminate instead of the FUNCTION SETUP LED. Two beeps will be heard. The setting process is now complete.
The UltraRacer will only return to its default setting when the buttons "A", "L", and "R" are pressed at the same time BEFORE you turn on the console's power. After about two seconds, the UltraRacer will generate three beeps to acknowledge reset button configuration is set. To reset a particular button, first press the SET button, then press the relocated button twice and then press the SET button once more until the LED light goes off. THe button's original function is used as a default button for further relocation.
These instructions were told to me bay a company selling these controls on AMAZON. I have been trying to reprogram mine and cant figure out where the "R" button is.
my nhl 09 freeze on my pc frequently, 1g ram, inte core duo, 1.73 ghz, intel graphics accelerator...
(More)
my nhl 09 freeze on my pc frequently, 1g ram, inte core duo, 1.73 ghz, intel graphics accelerator 950
xpadder reads the right analog stick moving left while it is stationary on the contoller. the...
(More)
xpadder reads the right analog stick moving left while it is stationary on the contoller. the contoller is not broken because it works fine with an other computer any suggestions to fix it please?
hooked up Ultraracer to usb game port adapter,calibrates ok but throttle control wont work, have to...
(More)
hooked up Ultraracer to usb game port adapter,calibrates ok but throttle control wont work, have to use button to accelerate.whats up?
