SOURCE: how to install an alpine cda 9851
you go to a stereo shop..(walmart autozone etc should also do) buy a mounting kit and a wire harness adapter. The wire colors on the adapter match the wire colors of most aftermarket decks. MAtch the wire colors and connect...make sure to tape wires well as if they touch you rick damage to your deck.. install the mount kit plug in your cd player and slide it in and you are good to go..
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
SOURCE: No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
SOURCE: connecting my alpine cda-9886 to my steering wheel contols
You will require a BMW steering wheel interface module.
Made by PAC.
SEE IT HERE
Thanks for using FixYa!! A Very Helpful rating is appreciated for answering your FREE question.
