Computer wont charge. Plugged up and still wont charge. Is it internal, battery or charger?
  • 2 more comments
  • chosenvessel Nov 07, 2008
    No the computer wont charge at all. I have a laptop so obviously my battery is close to dead, and I was trying to figure out if the problem was in the charger, or the actual charger jack.
    Not even with the battery out it wont function normally
    No it dosent work at all. When i plug up the adapter it doesn't power up at all.
  • Johnny Massengill
    Johnny Massengill May 11, 2010
    When the computer is plugged up can you use it? Does the computer operate normally when you have it plugged in to AC power?
You could try and get a universal type charger that has adapters for most laptops. That would most likely be the cheapest thing you could try. I have also seen the jack on the computer be disconnected from the motherboard of the computer because of broke solder joints. It could be either the charger or the jack but the charger is easier to check by trying another known good charger. At that point if it doesn't work, you could have a jack problem on the laptop. If that turns out to be the case, I would take it to an authorized repair center due to the fact that laptops are not easy to work on and are easily broken.
Posted on Nov 09, 2008
No, either the charger is broken or the charger jack is. Even with the battery out it wont function normally. Any guesses?
Posted on Nov 07, 2008
  • 345 Answers
I'm not asking if the computer will charge, I'm asking if when you have it plugged in does the computer operate normally. You should be able to take the battery out of a laptop and plug in the computer in and the computer should still operate.
SOURCE:
Rv510 plugged in but no lights on my laptop
You need to check all of these: 1. External charger, 2. Battery, 3. Internal charger, 4. Software. First, check if the battery is fully charge (or more than 80% charged). Second, use a tested good working battery charger/ac adapter to test your ac adapter (go to local electronic stores and test your laptop with their ac adapters). Third (if your ac adapter and your battery are good), then check your Power Options (click Help and search "power option" if you don't know where it is). If the Power Options is ok, then your motherboard (internal charger) has a problem. You need to bring your laptop to trusted local laptop repair shop.
Feb 28, 2014 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Battery wont charge
Is it a different charger? If it isn't try plugging it into a car or at home on the computer or the wall. If that doesn't work maybe getting it checked out will help.
Jan 07, 2014 | Amazon Kindle Fire HD
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
My daughters Acer wont charge so the battery is dead. The laptop wont even come on when the charger is plugged in but i have an Acer an charged her battery in mine then it charged and it worked in hers. Is...
first try to use your charger into another laptop, if the the another laptop was charged using your charger, it means your battery is the problem, but if it is still not charging it means the problem is your charger. then try your battery to use it into another laptop, as same as the i mention in the charger, if they or both fine, maybe the problem is the batery terminal of your laptop.
Dec 07, 2010 | Acer Aspire 5315 Notebook
My camera battery ran out and when i plug it in to charge it with the original charger nothing happens at all, cant switch it on and it doesnt charge, it wont do off the computer either, i tried it with a...
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
May 27, 2010 | Kodak EasyShare M863 Digital Camera
Today i turned on my garmin after a few months, it was working will for about 2 min, then it lost satellites, so I turned it off, then tried to turn it back on, but it never turned back on. the battery...
If the GPS's internal battery is allowed to discharge too far, it will not be possible to recharge with the card charger, until it is brought up to a certain level. Connect the nuvi to a computer with USB cable overnight. This will trickle charge the internal battery to a level that will allow the car charger / cradle to keep the GPS charged from that point on. Anytime the car charger fails to recharge the internal battery, the USB charge method will have to be performed first.
Oct 21, 2009 | Garmin nuvi 200W GPS Receiver
My Slick Mp3 Player wont charge
Your player may be unable to recharge or the charger may be defective.
Nov 28, 2017 | Audio Players & Recorders
It wont charge on my computer
Unfortunately, the USB cable is only used to download photos from the camera. It will not charge the battery. You need to purchase a battery charger, and because the battery is proprietary for this camera, you will probably have to get one from Canon (unless you can find one on eBay or Amazon). The charger (in the US) is the CB-2LV and Canon sells it here for $50.
Dec 03, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery wont charge
This camera not charged via PC, you can charge the battery only with wall charger(comes with box).When camera is plugged to PC, you can´t use it as a camera, only as a memory card.You can watch your stuff in PC( PC recognise a camera as a flash memory, no more).
So, this is normal..Charge your camera with wall charger(Full charge Red light not flash!, if light flashed camera is charging) Unplug and use as usually!
Regards
Alex
Vivitar 7300X
Nov 22, 2008 | Vivitar DVR 7300x Digital-8 Camcorder
SanDisk Sansa m250 MP3 player
hey :
sir you damaged your battery by charging it with the razor charger.
the razor charger have more volts than your device sw the only solution you got is replacing your devise's battery .
click here to purchase one
Aug 12, 2008 | SanDisk Sansa m250 MP3 Player
Open Questions:
Computers & Internet Logo
162 people viewed this question
Ekse
Alun Cox
