Question about Autodesk AutoCAD 2004 for PC
Help me for this problem please
I have program autocad 2004 on vista it can not open .help me please to let it run
  • Anonymous Nov 08, 2008
    after i open autocad by this way i have this message
    your applicaion was not able to obtain a license becouse the FLEXlm license manager could not determine where to find the licensing data it needs . please choose one of the following ?
    specify the license server or license file ?
    how can i get license file
  • elizabeth sanchez Feb 28, 2009
    i installed acad 2004 to my new computer, but it is requesting to authorize the product but i forgot all the information? help
  • 73 Answers
Hi Hamzawork Autocad 2004 is designed to be used with Microsoft Windows XP (Professional, Home Edition, or Tablet PC Edition), Windows 2000 Professional, or Windows NT 4.0 (SP6a or later) therefore I'd suggest to run your Autocad 2004 using Compatinity Mode --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Posted on Nov 07, 2008
  • pmgca Nov 07, 2008
    I saw you new post and the fact that you didn't understand what compatibility means. This doesn't make my answer inappropiate. You can add a comment and ask for follow up. In fact I did it in your new comment
    For the record, see how the same solution worked for other user
    http://www.fixya.com/support/t618092-con...
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
I have program autocad 2004 on windows 7..it can not open .help me please to let it run
Since it is the 2004 version, it may not have the windows 7 support. You can try to run windows 7 in XP mode. (It is a virtual XP machine within the windows 7) The purpose is to maximize compatibility.
Jan 30, 2010 | Autodesk AutoCAD 2004 for PC
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
AutoCAD 2004 / Windows 7 compatibility?
If it works in Vista you shouldn't have any problems. Easiest way to find out is to install it!
You can always just uninstall the program fi you run into problems.
Dec 05, 2009 | Autodesk AutoCAD 2004 for PC
Where can i find administrator in the compatibility tab? Trying to run autocad 2004 using vista
Right click on the desktop icon and select Properties. Then select the compatibility tab. At the bottom of the tab you will see Privilege Level. Check the box that says "run this program as an administrator"
If you have not installed the program yet, right click on the installer file (usually setup) and select run as administrator.
Regards.
Nov 18, 2009 | Autodesk AutoCAD 2004 for PC
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
On your desktop, you should have an icon to open your Autocad program--> right click on it--> a menu will open--> Properties--> Compatibility--> Select a version--> Windows XP, for example
Nov 07, 2008 | Computers & Internet
Conflict with Autocad 2004 (using Windows Vista)
May 23, 2008 | Autodesk AutoCAD 2004 for PC
Autodesk AutoCAD 2004 for PC Logo
392 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
