Question about GoVideo Go Video DVD/VCR Combo
Go video DV2150 not working
My go video dvd does not play. The screen says disc charger or bad disk. Ive tried numerous good disks..can you help troubleshoot for me.. The vcr part works fine...,,Thanks
  • 2,712 Answers
Try using a lens cleaner. It could be that the lens is just dirty. If that doesn't work, it could indicate a problem with the optical assembly, which may result in expensive repairs.
Try the leans cleaning first. Kits are available in most stores. Should that not work, then shop around for rates from various repair shops, and if the cost doesn't warrant it, best go in for a new unit..
Posted on Nov 07, 2008
Keeps telling me bad disk...the dvd works in another machine. What does this error mean?
Some players are better then others, try a different disc, if it plays then, player is fine, it's just not got a good enough laser eye to read the disc you want to play or laser eye is dirty. You might try cleaning laser ,player to see if that's problem. If it won't play other disks even after cleaning then it's time to replace player. Not sure what type disk your trying, dvd or blu ray, but I've noticed that dvd's play better in blu ray players, they have better laser eye for reading disc.
Mar 05, 2016 | Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
My Go Video dv2150 won't play my dvd's recorded on another unit.
Some DVD recorders / players work on different format disks
Some will only work with R+ (or RW+) Others will only work with R- (or RW-) some will work with both + and - formats. Check your user manuals for both machines - they may not be compatible at all.
Feb 18, 2011 | GoVideo DV2150 DVD Player/VCR
No matter what disc I put in it wont play and Bad Disc comes up on t.v. I know the movie discs are good ones.
Hello marciafoxmar,
If you know for a fact that the discs you are putting in, then there is obviously something wrong with the DVD player. When you put a DVD in your player, can you hear it spinning the disc at all? If your DVD is not even spinning the disk, I'm afraid your DVD player might be toast. If it does spin your discs, try a lens cleaning disc (available at pretty much any home electronics store or large chain store that sells home electronics). If that does not help, let us know and also let us know if you would be comfortable opening your DVD player.
Mar 02, 2009 | GoVideo DV2150 DVD Player/VCR
Will not play a game
this usually happens to bad/damaged/dirty game disks. try cleaning the disks. if that doesn't work, contact microsoft via
Jan 31, 2009 | Microsoft Xbox 360 Console
Video copied to disk but cannot view on PC or other DVD players.
This is the unfortunate thing with copying DVD's. Unfortunately when a DVD is copied only certail players will play it back. I can burn a disk on my laptop and it will play fine in the laptop and on my Sony DVD player, but my Samsung will not read it. This is why when you burn DVD's it's important to find a brand that is read by numerous DVD players. Try using the Sony disks.
Hope this helps.
Nov 12, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Keeps flashing "Bad disc".....
Try playing a CD instead of a DVD, if the audio CD plays normally that means that the laser on the DVD side is defective. This devices come with 2 laser picks, one for CD and the other one for DVDs.
Apr 04, 2008 | GoVideo DV2150 DVD Player/VCR
Go video DV2150
Compra un disco limpiador de lentes laser e insertalo en el dvd para que se limpie si no se soluciona llevalo a un taller para que le den mantenimiento.
Mar 28, 2008 | GoVideo Go Video DVD/VCR Combo
Dvd player problem
get a dvd cleaner from best buy. mine did the same thing, it would not play any dvds so i resorted to vhs, and once i had watched all of those, i finally got a dvd cleaner and now it works fine
Jan 20, 2008 | GoVideo DV2150 DVD VCR
Bad disk
if this disk plays on other sources then it is not the disk and sounds like it is a problem with the laser or the motor that pushes the laser along the disk if it dont play no disk at all then it is the layser if you have used a good quality lense cleaner and that didnt cure it then you could try if you are ok taking the case off leave it for 24 hours to make sure no electric is running through it and look where the laser eye is it should be neer the middle where the center of the cd sits if it isnt gently push it back to the middle this will recalibrate your laser then put it back together and try again if this dont work you will then have to get a replacement laser unit these can be expensive but you should be able to fit it your self as the wire areconected by conector but before you do this make sure you use a good lense cleaner as the cheaper ones wont work all the time and listen if the cd is spinning in the unit if its not spinning then you need replace the unit if you dont feel up to it then a repair shop will do this for you their si no way round it other than to replaceit they usually last the life of the warranty they are made to last no longer hope this is some help but not much more you can do
Aug 15, 2007 | GoVideo DV2150 DVD Player/VCR
GoVideo Go Video DVD/VCR Combo Logo
64 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
