Question about Acer Computers & Internet
BIOS inoperative. Attempted to flash bios my Acer - Aspire5610Z and i been unable to get it to show any life. Tried to locate BIOS to disconnect & reconnect in hopes of having it reset automatically, no dice.
  • delsenia2002 Nov 07, 2008
    I will attempt to replace the motherboard, and will inform you either way. Thanks in advance for your help.
    President:
  • 624 Answers
On the motherboard you can clear the bios. Find the pins that are listed as "CMOS", it should be 3 pins and 2 are jumpered together, just take off the jumper and move it to the other side. Example: If pins 1 and 2 are jumpered, move the jumper to pins 2 and 3. Then after about 30 seconds, put the jumper back the way it was. and this should clear your bios.
Posted on Nov 07, 2008
  • Acer Master
  • 1,879 Answers
If you're updating : revert to the previous version
else : keep on trying
  • Acer Master
  • 19,396 Answers
If you failed in the middle of a Bios upgrade, the motherboard is badly damaged. The best thing to do is replacing the motherboard.
  • Ginko
    Ginko Nov 07, 2008
    When you fail a Bios update operation, what happens is that the data in the cmos chip gets damaged, and the bios cannot start the computer anymore.
    If the computer can still start and read the disk drives, you can try to fix it by restarting the bios flashing operation.
    If the computer does not start, then the only fix to this problem is by removing the CMOS chipset (using apposite tools, the two screwdrivers method can damage the chip), then mounting the bios chip on an eeprom programmer, and reflashing the chip with the bios image.
    Today this kind of job is not done very often, not even at a repair shop, as due to the low cost of motherboards, when this happens, it is usually better to replace the motherboard.
  • Ginko
    Ginko Nov 07, 2008
    anymore.
    If
    Today
    If the computer is starting instead, and all you want to do is reset the bios and bypass bios password, then access the motherboard and remove the motherboard coin battery for one minute.
Looking on the motherboard of ACER Aspire E5-471-37TL but I cant find the CMOS location.
See link below of its for another similar model but location should be the same
Jan 02, 2015 | Acer Aspire Computers & Internet
Gateway 504gr bios update failed
You maybe using the wrong version, it's already updated, or simply can not be upgraded.
Unless there is a TRUE need to flash, and usually there is not, I would stay away from. So many people try and fail, only to wipe the CMOS, leaving the system useless. Here is some sound advice on the subject.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 01, 2012 | Gateway 504GR PC Desktop
Acer aspire 5004 black screen after BIOS completes loading
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 16, 2012 | Acer Aspire 5004WLMi Notebook
Unable to reset password on Acer Aspire one D255 and so unable to access netbook. Down loaded Bios on to memory stick however having problems with Flashit exe. Can you help??
you can't reset BIOS passwor by flashing the BIOS. The password is stored in a different chip. Contact Acer for the master password if you are the owner of the laptop.
Dec 28, 2010 | Computers & Internet
Would someone please tell me if I have a battery problem or a fried suffocated Acer problem? My Acer 4520 was setup on a mattress bed then placed into hibernate mode after an hour. 20 minutes later I heard...
Obviously it's not a battery problem. When you power on Acer, there's some running noise or not ? If there's such noise & just LCD has no sign of life, and you can't even access to Bios, it's just LCD cable connection problem. Often, LCD cable is disconnected from motherboard. It can ba happened very easily on shaking your laptop. It's possible that your hard disk is sick, then your Bios can't ditect its presence;
Jul 14, 2010 | Acer Aspire 4520-5582 Notebook
I was trying to go through recovery thinking I could get more speed on laptop and I messed comp. up. Only get a blank black screen. tried powering down, rebooting, still can't get on. Help!! i was trying...
Flashing the Bios is a LAST DITCH effort to resolve Hardware issues. You should NEVER flash the bios unless you are absolutely certain it's the correct bios for your computer, also NEVER flash bios from within windows..
There may however be a solution for you, Acer laptop computers with the Pheonix BIOS sometimes has a " flashback" feature, allowing you to revert to your original Bios..
You will need to contact Acer to get a Crisis Bios recovery disk from them. Or ask for further information on how exactly to recover from a bad bios flash.
May 30, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire 1800 not booting!
Did you make a backup of your original BIOS before flashing? If not you'll need to download the BIOS and reflash again. If you did then put your original BIOS back on the chip. This is definitely a BIOS problem. Worst case is you may have to purchase the BIOS from Acer or I've seen some 3rd party BIOS providers. I did not find the BIOS for the model you specified at the Acer site but I did find it at an English site: http://bios-repair.co.uk/ref/macercr.htm. It's L12 about $15.00? Good Luck
Apr 13, 2009 | Acer Aspire 1801WSCi Notebook
Acer aspire 3000 bios flashed
I see this alot in my store. It seems that Acer doesn't put the right programs under the right names. Anyway you'll have to get ahold of them to have them download you the correct BIOS for your model.
Mar 25, 2009 | Computers & Internet
Forgot all passwords, windows and bios
Disconnect the power supply, remove the battery, then locate and remove the BIOS battery for a minute or so. That should Flash/Reset the BIOS to no password.
Feb 06, 2009 | HP Pavilion n3290 Notebook
I have a dell optiplex, the primary HD is a Western Digital 160gb Sata I also have a LG DVD/RW combo drive set to master on the IDE channel. I recently attempted to add a 2nd ide maxtor HD and for the...
Hi there
When you into the bios settings choose default bios settings and save, reboot the machine and have a look in the bios again to see if the bios has picked the drive up
Good luck and kind regards
Jan 07, 2009 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
