Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Shakes violently and bangs on spin
This seems to be worse on starting the first spin. Once it gets going it's ok. I have tried using the machine with no washing in it, then the spin is fine. I have also tried it with only one wet towel in it and it is still really bad. My model is actually the WD 71
  • chrise123 Mar 26, 2008
    I have replaced the suspension and the top springs, the machine is level and not overloaded. The spin speed seems sensible but the motor still collides with the case on spin start up making a fearful banging.
    The drum just seems to have too much poorly restricted movement.
    I am about to give up unless someone out there knows a miricle cure!!
  • shantac Jun 14, 2008
    Transit bolts not the problem is the springs on the top of the drum that need replacing - where do you get them?
  • 67 Answers
Inbalnced load will cause it to shake also poss loosecondenser
Posted on Jul 09, 2007
    President:
  • 1,462 Answers
Transit bolts not removed. also can be caused by motor not winding up gradually into spin - usually a motor tach fault. most likely cause is transit bolts
Posted on Mar 22, 2007
SOURCE:
My TAWS800JQ1 washing machine drum seems like it has shifted and is off balance
The bearings are likely shot. But it's possible the spanner nut that holds the basket in place is loose or damaged. Remove the agitator to check spanner nut. Changing bearings is a big job, but if you are handy with tools and good at keeping your cool you can do it yourself.
Jan 06, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Our Maytag washer rocks violently during the spin cycle.It shakes the whole house and seems to be getting worse. We put shock absorber rubber mats under it but it just rocks off them.
Sorry to read about your problem, I hope this helps you out.
you must have a broken balance spring/shock on your machine...
I suggest you contact a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise during spin cycle
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
My brand new amana washer shakes violently when spinning
try adjusting the feet on the bottom of the washer the floor may not be level to adjust the legs turn them with a wrench or if the lock nuts are not tight turn the legs clockwise as you look at the front of the machine till all four feet are sung on all 4 corners. This is the most common problem. hope this helps and thanks for using fix-ya
Feb 15, 2010 | Washing Machines
On high spin the drum bangs against the rear inside walls of the cabinet. Dents are noticable from where it violently shakes.
There is usualy a switch located under the agitator that senses when the machine is spinning off balance. What are you drying? But it sounds like a bad off-balance switch.
Dec 16, 2009 | GE Washing Machines
The drum shakes violently and is very loud during spin cycle
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Dec 01, 2009 | Frigidaire GLTF1670A Front Load Washer
Samsung P801 Front Loader shakes violently during spin cycle.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Feb 23, 2009 | Hotpoint Ultima WD72 Front Load...
Washer shakes violently when spinning at high speed.
is the washer level and on solid surface both will cause machine to dance
Feb 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Shakes Violently
run it with the top access panel open and watch,
while you are there try out the suspension ,
you do it like an old car push it down , push to sides etc .
it should resist and return well. no bounce. tight.
May 15, 2008 | GE WBVH6240F Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
348 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
