Question about Western Digital (WD3200JS) 320 GB Hard Drive
Connecting external hard disk to my pc
Actually,the system is detecting the hard disk but it is prompting to install the software for the hardware to run.it is not running as if a pen drive is running in the system
  • Anonymous Nov 08, 2008
    fastinnerhtml!
  • 55 Answers
when you connect your wd hard disk to your system it says a new hardware found and plz upload a driver for this. an another hand your pen drive will accepted.
if you make the external harddisk partition in a another pc. then it possible that is not show the patation of your external hdd partation. or it possible that is show the drive letter but nothing to open in the drive.
i suggest you to plug the hard disk with system and boot the pc. after booting process nothing shows then you download a proper driver form site. and upload to your system. if nothing then happen you partation it again. it sove your problem.
thanks
ramesh
Posted on Nov 14, 2008
Usb device not recognized
New hardware often comes with specific instructions for installation. Some want you to install software first - others want the hardware installed first. Make sure you're supplying the PC with what is needed - in the order it is needed.
If the device requires external power - be sure to provide it.
When prompted to allow connecting to the internet to search for drivers after connecting the hardware - be sure to allow it. If the PC is unable to locate drivers online, the device should have come with software on a disk. Insert the disk into the computer and tell the computer that you have inserted the disk and choose "removable drives". If no software was supplied, check with the manufacturer's website. Download the drivers needed for your operating system. If there are no drivers for your operating system listed, the hardware may not be supported on it. You should contact the manufacturer of the device to see if they have a "work- around" for you.
Jan 31, 2013 | Dell Inspiron N5010 Black
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
A blue and red flashing light and won't connect to computer
Hope this helps.
Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
It is not formatting., please help me
hi
follow these instructions
Instructions Things You'll Need:
  • Windows installation media (and product key)
  • Manufacturer software
  1. Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating system floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Determine which file system is to be used. Windows XP will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
this should help you.
Nov 28, 2010 | Computers & Internet
When I connect my seagate expansion external hard disk 500gb having p/n:9sf2a2-500 in windows xp(sp2) system, found new hardware wizard pops up and when I click next it says Cannot install this hardware....
either an issue with the hard disk, or with your system. Make sure the hard disk has power on it and if you can, it would help to test it on another computer to confirm if it works. If you have ruled out the possibility that it is the hard disk, next is review if the hard disk has system requirements you need to meet. If the requirements are met by your XP SP2 machine, you may try updating the computer's system software/chipset drivers and a BIOS update may also be necessary.
Aug 29, 2010 | Computers & Internet
How can i format my laptop
Step 2
Step 3
Step 4
Step 5
Step 6
May 06, 2010 | Computers & Internet
When i connect 500GB External USB hard disk on winXP machine .I get the display on my PC that new hardware found & asking for Drivers
Let the system to search for drivers automatically. Before proceeding that place any driver cd into the CD drive if came along with your ext. harddisk so that the drivers from CD will be automatically taken by the driver installer.
Thanks
Apr 12, 2010 | Seagate FreeAgent Pro 500GB External USB...
How do i format my packard bell easynote
Hello
  1. Step 1 Ensure that the hard disk is installed properly in the laptop. The drive cannot be formatted before it is installed, or if it's not installed correctly.
  2. Step 2 Gather the required software. The type of media will depend on the hardware in your laptop. Older computers without a CD-ROM drive, will require the use of the operating systemmag-glass_10x10.gif floppy disks. Laptops that can run Windows XP require the installation CD and product key. Older versions of Windows also have disk-formatting capability in the installation process, and the installation media is either a CD or floppy disk.
  3. Step 3 Place the installation disk or manufacturer software in the drive and then boot the computer. Early in the installation process, the Windows installer has a step that will detect any installed hard disks and allow for them to be formatted. The software from the disk manufacturer will also detect the hard disk and give you the option to format the drive.
  4. Step 4 Determine which file system is to be used. Windows XPmag-glass_10x10.gif will either work on a NTFS file system or an older VFAT file system. Choose the desired file system when prompted.
  5. Step 5 Decide whether the whole disk should be formatted or if the disk will be partitioned and each partition to be formatted separately. The Windows installer includes a menu-driven utility that will create hard disk partitions before formatting. If the hard disk is being formatted to replace an existing Windows installation, delete the existing partitions and re-create them.
  6. Step 6 Format the hard disk with the Windows installer when prompted. The Windows installer will let you know when it is time to format the disk and ask for confirmation.
  7. Hope this can help you, kind regards, andrea
Nov 13, 2009 | Computers & Internet
Install disk
Just connect the Hard drive to your system using the usb cable that comes along with it, it will automatically install the drive and your system will prompt you that a new hardware has been found and installed. You can then start to use after installation.
Sep 25, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
How i can format my laptop toshiba L300D can anyone tell me how to do it plz
If you have the windows install disk, just put it in and start a new install..there will be an option come up in the installation to format the drive.
If your laptop has a second hard drive listed that is very small that the recovery partition...go to it and run the recovery program
Aug 27, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Western Digital (WD3200JS) 320 GB Hard Drive Logo
144 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
