Question about Roper RAS6233KQ Top Load Washer
Washer wont spin
  • wevelyn17 Nov 10, 2008
    my washer will spin but spin slow but wont wash please help
  • 2,712 Answers
If your washer won't spin, check these:
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • Ifthe motor is running, your washer probably has a frozen pump pulley ora broken pump belt. To check the pulley, remove the pump from thewasher and try to rotate the pulley manually. If it doesn't turnfreely--if it's frozen or stiff--replace it. If the pump belt is brokenor looks quite worn, replace it--but be sure to check the pump pulleybefore you change the belt.
  • If the motor isn'trunning, the lid switch may be defective. If so, the washing machinecan't spin and may not function at all. The switch is inside thewashing machine main housing near the door frame. Often you have toraise or open the top or front of the washing machine to get to theswitch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • Thelid switch may be defective. If it is, the washing machine doesn'tspin. The switch is inside the washing machine main housing near thedoor frame. Often you have to raise or open the top or front of thewashing machine to get to the switch. If it's defective, you need toreplace it.
  • The motor coupler may be broken. ManyWhirlpool®-manufactured washers use a small, relatively inexpensivemotor coupling. It's plastic and rubber and is mounted to the shaft ofthe motor on one side, and to the transmission on the other. Over time,the coupler wears out and fails. You may need to replace it.
  • Abelt may be broken. Many washing machines have one or two belts. If abelt is broken or badly worn, you need to replace it with a genuinebelt from the manufacturer. (Some washing machine belts are designedwith special characteristics not found in automotive belts.)
  • Theclutch may be worn. If your washer is a GE, it may use a clutch to comeup to the proper spin speed. As the clutch wears out, it may preventthe unit from spinning well or at all. If the clutch is worn, you needto replace it. For this job, you probably want to hire a qualifiedappliance repair technician.
  • The drive motor may bedefective. Many washer brands use a reversing motor. For agitation themotor runs in one direction, for spinning and draining, the other. It'spossible for a motor to burn out in one direction and continue tooperate in the other. If this happens, you need to replace the entiremotor.
  • The transmission may not be shifting properly.Older washers produced by Whirlpool® have a transmission with anelectro-mechanical shifter. If the shifter becomes even partiallydefective, the unit may drain the water but not spin. This is a complexsystem, if your washer has a shifter problem, you may want to hire aqualified appliance repair technician to repair it.
  • Thespin bearing or basket drive may be worn or seized. These componentsallow the inner tub to spin freely inside the outer tub. When this isthe problem, you usually hear a loud sound during the spin cycle. Calla qualified appliance repair technician.
It spins only with the lid closed Forsafety, washing machines are made so that they spin only with the lidclosed. The lid switch prevents the spinning action when the lid is up.
Posted on Nov 07, 2008
Wont spin or drain
Does the machine agitate if so this eliminates the motor coupling could be a bad timer place unit in spin if motor hums then power going to motor eliminates this check the drain pump it is white and attaches to the motor with 2 spring clips if there is something stuck in it or a bad bearing won't drain if a washer cannot drain it will not spin hope this helps.
Jan 19, 2014 | Amana NTW5400TQ Top Load Washer
My washer wont spin, it washes but then it wont start the spin cycle.....please help
what is the model number and the brand name?most likely you have a bad lid's a saftey on most washers,the factory doesn't want the washer to run when it's in spin so if you were to open the lid while it was spinning the washer would shut down,if the lid switch is broke it's like the lid is open and it won't spin or run
Jan 23, 2011 | Washing Machines
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
May 28, 2010 | Roper RAS8445KQ Top Load Washer
Front load Washer will not do a final spin
my front load washer wont final spin and show me e20 code
Aug 03, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Mar 10, 2009 | Washing Machines
Machine washes but ont the spins it wont kick the clutch in
yep the clutch is going out you are lucky it will spin at all
Jan 13, 2009 | Whirlpool LSB6200KQ Top Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Washer doesnt spin
ck the coupling between motor and gearcase it is probably broke and won't drive the transmission
Nov 08, 2008 | Kenmore 24032\24036 Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
164 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
