Question about Astoria Argenta SAE-2 Espresso Machine
Astoria SAE 2 Programing
I just purchased a slightly used astoria sae2, and it does not want to program. I turn the switch to "on", push the program button, etc. as the manual says, but it only does what it was originally programmed to do.
  • Alex Torello
    Alex Torello May 11, 2010
    Please run though the programming process for me. You may be missing a step.
The key is that you have to HOLD the programming button in for about 5 seconds before the system will go into programming mode. All the lights will come on and you will know you are ready to program the various shot buttons.
Posted on Dec 23, 2008
All the program buttons on my Astoria SAE2 were flickering at once. I turned the machine off and on again and it was gone but am wondering why it was flashing.
if the machine runs on 220, then it will do that with a power surge, because sometimes, when there is a surge, it drops to 110 power it is enough to do this, if it is wire and on 110 power, could be a programing issue that is triggered from a power surge. Most likely it was a power surge, that is common, especially if it is 220 power, machine will run if only 110, power, but wont operated fully for the proper steam, boiler temps etc, if does not have enough amp, just enough to flicker. Hope this info helps. Thanks Mr Bean Man from fixya
Jun 12, 2011 | Astoria Argenta SAE-2 Espresso Machine
Hi I do have a problem with my Astoria SAE2 Coffee Machine. One side of the machine working perfectly. On the other one there are 4 buttons and those are flashing red. during this process we can not serve...
Sounds like the flowmeter which sits under the drain tray is not working properly for that side, or the programming is off, or the head is blocked. There is a manual switch for that head when you press it does water flow? If yes then problem is flowmeter.
Jan 24, 2011 | Astoria Coffee Makers & Espresso Machines
I have bought a used Astoria sae Espresso Machine and I need to know how to clean it - can you help?
You'll want to back flush the machine with espresso machine cleaning powder: and regenerate the water softener regularly.
May 21, 2010 | Astoria Argenta SAE-2 Espresso Machine
Maximum water supply pressure
About 3 bars, not more that 5 or you will need to install a pressure regulator on the line.
Apr 10, 2010 | Astoria Argenta SAE-2 Espresso Machine
How do I program an astoria SAE-2 espresso machine?
Look behind the right steam valve, you will have to remove the front top panel, there might be a small toggle switch, note the position. If switch is not there then it is on the black CPU box. Press the program/stop button if all lights come on move forward if not then move the toggle switch to opposite side and press program button.
When all four lights are on press a button when you get the desired volume press stop, continue until buttons are programed then move toggle back to original lock position.
Sep 28, 2009 | Astoria Argenta SAE-2 Espresso Machine
We Have an Astoria SAE 2 Group and am looking to find the NSF label location on the machine. If i can't find that, how can I show health dept that it is NSF certified ?
On the right side of the machine next to the serial number is the most likely spot for the NSF sticker or tag depending on the model of the machine it may only have an ETL listing.
Apr 07, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Astoria SAE-2
Contact Astoria and I'm sure they can provide one for you.
Mar 14, 2008 | Astoria Argenta SAE-2 Espresso Machine
Astoria Argenta SAE-2 Espresso Machine Logo
688 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
