Question about McCulloch 26cc Backpack Blower with Dual Jet Engine and Easy Start
McCulloch 32cc backpack leaf-blower
I bought this at an auction, it looks fairly new, but has no fire getting to
the spark-plug. I eliminated the on/off switch but it still won't fire. Where
can I get a owner/repair manual for it?
  • Anonymous Dec 15, 2008
    I HAVE THE SAME PROBLEM IVE TAKEN IT APART AND HAVE HAD OTHERS LOOK AT IT. I HAVE REPLACE THE TWO FUEL LINES ALSO.
    1. IT WILL NOT RUN WITH THE CHOKE OPEN .THIS THING SUCKS.
  • Jerry Novacek
    Jerry Novacek Aug 05, 2012
    check for spark = possibly the coil is bad or setting is wrong.
Mcculloch MB3202 anti-vibration back pack leaf blower, runs better at the middle setting of the choke than it does if it's wide open the way it should be. Can't get it to blow leaves well. Owners manual lost. ANY ADVICE???????? New gas, spark plug starts on the first pull but just doesn't give out like it should.
Posted on Nov 04, 2009
Volvo Won't Start
Replace your spark plugs and spark plug wires. This will probably fix your problem. Be sure and check your firing order in case one or more plug wires are hooked up wrong. This sounds like it might be your problem.
Feb 09, 2018 | 1984 Volvo DL
Husqvarna 372xp won't start... Mysterious
I recently bought a brand new 372XP and spent the first day trying to start it as per the instruction manual with no success, never even fired once. Removed the plug to find plenty of fuel and that the plug has a good spark. Left it until the next day mainly to allow my arm to recover (& scour the internet for clues). I found a forum that said not to use the decompressor and sure enough without the use of the decompressor button it fired first go with the choke on then I reset the choke & it ran properly on the second pull. The decompressor button can be reset with fine nosed pliers or removal of the top cover by undoing three screws. Good luck it's a great saw once you know how to start it.
Apr 01, 2012 | Husqvarna Chain Saw Models 371, 372xp
'95 Jimmy 4.3L won't start unless plug wire is removed
every possibility that the timing ( firing order) is wrong from what you describe
bring the engine to tdc no1 piston on compression and that is no 1 plug lead in the distributor cap
Mar 15, 2017 | Cars & Trucks
Just bought a 2007 LT1000, 16 hp Craftsman riding mower. The original owner bought it new and passed away in late 2008. The mower was not started but a couple of times since that time. Now, after sitting...
when they were jumping it with a car battery if could have damaged the stater solenoid. You may have to replace the solenoid or check for loose wires going to the solenoid, all so check and clean the wire plug on the key switch
Aug 18, 2011 | Craftsman Garden
Have spark and getting fuel won't start 2002
Have you checked all your safety switches? Kill switch, kickstand switch, neutral switch? What do the plugs look like---are they wet and smell like gas? Are you getting a nice blue spark across the electrode? Troubleshoot the basic stuff first to eliminate those possibilites.
Jul 06, 2011 | 2002 kawasaki VN 800 A Vulcan
Engine was running fine and shut it off 5 min. Tried restart and engine cranks but won't fire. Dual tanks 1 new fuel pump.Switch tanks still no start, tried next day, runs fine???????
Step #1 in any automobile diagnosis is "Isolate the system"
Switching fuel tanks may have seemed like a good idea, but it did not definitively determine whether the the fuel is getting to the fuel rails, so you are no closer to eliminating the fuel devery system than you were when the engine died.
If it does it again, you should do the easiest things first.
Pull a spark plug wire and check to see that you have good spark reaching the spark plugs. Good spark will eliminate the entire spark control system.
Only if you have good spark should you suspect a "part-time " fuel system problem. The Fuel delivery system can be eliminated if actual fuel pressure is checked at the fuel rail. (although you could still have injectors not firing for one reason or another)
You are losing one of these systems. (spark or fuel) only once you have determined which one, can you continue diagnosis to pinpiont the failure.
Oct 10, 2009 | 1991 Ford F150
1987 Honda shadow vt1100c no spark at any plug
The voltage on the coils is present except at the instant of firing. The interruption of the voltage is what causes the coil to fire. The cdi box is what causes the voltage interruption.
The interruption is very hard to detect. You are not the first to be stymied by that box. If you have access to an oscilloscope, I think you can see the pulse if it occurs.
Jun 07, 2009 | 1989 Honda VT 1100 C Shadow
McCulloch 26cc Backpack Blower with Dual Jet Engine and Easy Start Logo
3,181 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
