Does not power on sony kds60a3000
Hi
the TV Lens Come on for a couple seconds than back off the power light keeps blinking red when off, i changed the bulb, the power board and not sure what it could be.
thank you for your help.
  • 2 more comments
  • charmouta Nov 07, 2008
    i need a little more help than that is there someone else that can help?
    this like saying you're on your own.
    can someone else help please
    thak you i have already changed the power board with a new that was my first fix choice, could it be faulty board?
    here's another thing i put the old power board back it does not light up the bulb the new does for a few seconds.
  • 83 Answers
Try link for serice manual -----
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/KDS60A3000.pdf
Posted on Nov 07, 2008
    Scholar:
  • 155 Answers
Check the thermal sensor fuse part# 1-910-023-93 or possibly one of the four fans.
If the unit goes into Fan/Thermal Protect shutdown it can be difficult to determine the cause since the unit turns off too quickly to troubleshoot.
Solution: Ground the data line by inserting a jumper between pins 3 and 6 of CN44 on the H4 board. This overrides the protection circuits for troubleshooting. Do this right after turning the unit on and as soon as the lamp is seen lighting. Check pins 2, 5, 8, and 11 of CN6000 on the G2 board for less than 1VDC. Any voltage higher than that indicates a faulty fan. If all voltages are within specs, the H4 board must be replaced. If a fan is found defective, the optical block will need to be replaced if it is located inside the assembly.
H4 Board Part Number: A1054674A
Replace the following part based on which pin of CN6000 is out of specs:
Pin 2: Fan 1 (part of optical block)
Pin 5: Fan 2 178723211
Pin 8: Fan 3 178706511
Pin 11: Fan 4 178708111
Optical block Part Number:
A1084662A
thanks.
  • 435 Answers
Take a look at this web page:
http://www.iwaynet.net/~nesda/SonyBlink.html
It is a good tool for getting some idea of Sony sets.
You say your light stays on and is blinking, then look at the various comments for that number of blinks on that above mentioned site.
  • 4,889 Answers
The blinks serve as a diagnostic code that helps identify the problem correctly.. Please post the number of times it blinks between each pause.. Sounds more like a power supply board issue though..
  • eagle338
    eagle338 Nov 07, 2008
    Yes it can be a faulty board.. The best way to check is to grab a copy of the service manual and check the voltages accross the circuits and compare them with those in the Service manual..
  • eagle338
    Can be tiresome but no other go..
    Scholar:
  • 44 Answers
Have your tv checked by a tech your problem is in the power supply or related circuit.check your regulator,along with some caps the microchip.some times with these tvs you will have to replace the main board.
If the flashing seems irregular, it may be showing a trouble code.
Considering the number of folks having problems with their newer flat-panel sets of all different brands, if you can find a TV repair shop in your area any more, you might want to have this one repaired. They were quite reliable as you probably know if this is the first failure you've had.
The problem is probably pretty straight-forward and in the power supply section of the set, an area that isn't prohibitively costly to repair and uses parts still available and likely even in stock in a decent shop.
If you are in the US, I would recommend further that you go shopping for an honest repair shop in the member directory of your local Better Business Bureau.
You should contact an authorised Sony repairer as they have a fix which took abot half an hour to solder in a replacement part which had been damaged by over-heating. Ours was fixed under extended warranty.
  • 19,396 Answers
You need to get the service manual and follow thoroughly the troubleshooting diagrams to fix the problem.
Common problems can affect vertical deflection and convergence circuits, but the boards must be tested to find out what the problem is.
  • 10,594 Answers
How many time light flashes in your Sony KDF-60A3000
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Nov 07, 2008
    I mean KDS-60A3000 model.
    Charmouta,
    to whom you are replying?
    You need following service manual to rectify problem in your TV.
Sony KDL-52w5500 black screen 13 blink then 14 blink
You have a couple of problems if you are sure there are 2 different blink codes. 13 blinks indicates a backlight balancer error which would explain your no light condition. 14 blinks would be a TCON board error which is the driver board for the LCD screen. Either error would keep the screen black.
Mar 21, 2014 | Sony KDL-32M3000 32 in. LCD Television
Sony bravia tv problems
hi you could try this, press the arrow up button on the remote and the power button on the tv for a couple of seconds this may reset the tv good luck
regards
shaun
Jan 06, 2014 | Televison & Video
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
Hi I have a Sony Grand WEGA KDF-60XS955 TV
Ur right the cooling fan is defective,check it,clean it might work normal again.Not, than the cooling fan must be change.
May 04, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
TV(KDS60A3000) not turning on.
sounds like you need a new lamp
Sep 09, 2009 | Sony KDS-60A3000 60" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
