Question about Dell W1700 17 in. HD-Ready LCD Television
Screen blackout Blackout was sudden, not incremental, perhaps suggesting video circuit failure. Audio OK on computer and TV. TV Channel selection OK. Need to know how to verify problem is not LCD screen and other repair options. How may Iobtaina service manual?
I had the same problem and fixed it with a new backlight inverter board. It was a pretty easy install. The part is available on eBay. http://cgi.ebay.com/New-Inverter-for-Dell-W1700-17-inch-LCD-TV_W0QQitemZ400017456720QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Posted on Dec 26, 2008
SOURCE:
No picture w/ sounds and backlight on
The screen controller circuit board isn't working. The board you're looking for is the one that has the wide flat ribbon cable coming from the bottom of the screen
Jan 05, 2014 | Sony KLV32S550A 32 LCD TV
Screen blackout supra tv
Check the horizontal scan output section circuit for any fault. Check whether the filament of the CRT is glowing. If it does, the horizontal section circuit is working, and you have to troubleshoot all other voltages at its video output circuit. Check the CRT base socket too. If it has any faulty connections, this kind of fault can occur.
google.com/+GopakumarGopalan
Nov 25, 2013 | Televison & Video
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
Sounds could be heared upon switching on of the set but the screen has no raster (means total blackout as if the unit were off. a small red LED located @ the front panel continuously blinks just like the...
Since you said the the pictur tube is glowing, your EHT system is OK.
After selecting a channel if sound is alright the TV up to signal
detection is working OK.
The problem now could be in video amplifier circuits. Check the grid
voltages of the picture tube.
Or switch off TV, and check the resistance values of the resistors
connected to the picture tube pins. Replace the defective resistor.
Check after removing one end of the resitor as it will misguide you if in circuit.
Aug 23, 2010 | Televison & Video
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Onida Ky Thunder tv blackout
my onida ky thunder giving fault led blinking after plugin and after 5 second goes to stopped mode
May 11, 2008 | Televison & Video
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
Dell W1700 17 in. HD-Ready LCD Television Logo
577 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
