Question about Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish
Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
Our Fan has absolutely no signal going to it all of a sudden after years of service. I have checked the DIP switches both on the Transmitter and the Receiver in the Fan. They are set exactly the same, the Remote has a brand new 9V in it, and the Red LED is on every time the button is depressed - no light to the unit, no fan action, and the switch on the wall is ON. I have tried shutting the power down, removing the battery, checking the switch, transmitter & receiver, with no response at all.
Can someone help me with what the problewn might be? Could the switch on the wall all of a sudden go bad? The only thing different is that a carpet cleaner guy switched the switch without knowing the fan needs the remote.
How do you reset this unit outside of what I've already done per the Owner''s Manual? I have a Hampton Bay 52" Zinfandel that has a problem with the fan not turning off. I am forced to have the fan on whenever I switch the light "ON". The fan also stays in the same setting (high). I am not able to turn it down (it has three settings). The dimmer on the light still works, but I am not able to turn the light off like I used to with the dimmer button. I have to turn the wall transmitter to "OFF" to turn the light and the fan off. This model does not use a remote control, and the receiver on the fan is wired, so there are no battery issues. Any suggestions?
  • muttdogs Nov 07, 2008
SOURCE: Older Model Hampton Bay Ceiling Fan: The Redington II w/Remote Control
Ironically, i am having the same problem with TWO different Reddington's in my house.
One is brand new, just hung a few weeks ago, the other is about 3 years old.
The new one -- the lights are stuck in a constant dim, bright, off, dim bright off, and the fan wont turn at all.
The old one, the lights wont come on and the fan will only spin slow.
Both failed within a day or two of each other, and this is driving me nuts.
I thought it might be the remotes, so I took both remotes and pulled the batteries out of each, but that didnt do anything.
If anyone else is having this problem, please post.
Posted on Jan 13, 2008
SOURCE: Installing ceiling fan with two switches AND a remote
I have a hampton bay ceiling fan with light fixture all connected to a wall switch and controled by a remote. The light does not work any more and I have replaced the bulb with three different light bulbs and it still won't work. There is a green wire coming off the bracket but there is no ground wire coming in from above. There are two wires coming in from above ( the box in the Attic)
one white and one black and they are connected properly. All the wires are taged from the remote receiver, the fan and the light and are correctly connected. Any suggestions?
Posted on Mar 30, 2008
  • 7 Answers
SOURCE: Hampton bay ceiling fan with built-in remote receiver
No fan disassembly, just the houseing mounted to the ceiling. the transmitter is in there. U can try and match it to a new remote or look for some number on the transmitter. However u can usually buy a new remote and transmitter for 30 bucks and just swap out the transmitter. They come labeled and r pretty easy to install.
Posted on Jun 12, 2008
WeListen2You
  • 538 Answers
sounds like the radio signal amp is blown..that is a full replacement deal..that would explain this, and the power
#glitch could certainly cause this problem..
Posted on Oct 26, 2008
  • 25 Answers
SOURCE: Hampton Bay Redington IV ceiling fan remote won't work
the reciever is under the cover for your fan to the ceiling. Try pulling the switches on you fan then using the remote after each try. then check your wall switches,,, it could be wired to one.
Posted on Aug 16, 2009
How can the remotes be set to separately control 2 fans in the same room?
Most have four dip switches in the transmitter & receiver. You need to match-up the dips in both for one fan. The dip switches in the transmitter are in the battery compartment.
Oct 05, 2015 | Dryers
Oct 26, 2008 | Hampton Bay 52 In. White Redington...
How to reset a remote control for a ceiling fan
Most have 4 dip switches in the receiver & transmitter. Just match them up. The dip switches in the transmitter are in the compartment where the battery is.
Aug 26, 2015 | Dryers
How do I get the remote to work fan and light
There are dip switches in the fan and in the remote that need to be set to the same numbers. You can set them to whatever you want, as long as they match. If these numbers don't match it won't control your fan.
Here's a few lines from the user manual:
"IMPORTANT! Before installing this control, check the factory dip switch settings. Refer to Figure 1. Be sure the dip switch positions of the transmitter and the receiver match, or the ceiling fan will not function."
Here's a link to the PDF manual, which has an explanation and a figure in the middle of where you can locate these dip switches on the transmitter and the receiver both.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/41316.pdf
Jun 24, 2014 | Hunter 27185 Remote Control
I need a hunter's ceiling fan remote part# 85095-01 can you help me?
To my knowledge there are not parts available for remotes. Have you checked to be sure that all your dip switches are coded identically, receiver and transmitter. There are no servicable parts on the remotes. You can purchase a new remote & receiver at Home Depot for $29.00. Be sure you have 120 volt at your fan and check your remote batteries.
Aug 22, 2011 | Hunter Ceiling Fan Remote Transmitter...
Electrical wiring guide for Hampton bay ceiling fan with remote control?
mcdevito75 here, I did a fast search and have a tech. support number -- 800-330-3267 Hope this helps.
Jul 23, 2010 | Hampton Bay 52 In. White Redington...
I have a Hampton remote ceiling fan with lights.The Redington 11
the carbon of remote which help to connect the points of remote is not working so purchase the liquid carbon and put on the inner points on remorte buttons
then i feel it strt working.
Apr 29, 2010 | Universal Remote Control Hampton Bay...
Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish Logo
216 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
