Question about Asko D1776 Built-in Dishwasher
Dishwasher overfilling Our dishwasher continues to fill and drain and won't stop. Our repair tech said the control board is bad. This is a minimum $400 repair. What are our options? If any.
  • 175 Answers
I have been working on ASKO for several years and have never seen one fill and drain at the same time. Usually if it drains and cannot be stopped, it is because there is water in the lower tray that needs to be removed or left to evaporate, and then it needs to be figured out why the water was there in the first place. If you could post back with more info (does it fill, sit for a while, then drain, or is it doing both at once) I would be glad to help. Good Luck!
Posted on Oct 18, 2006
Dishwasher overfills?
the water level sensor is disconnected but probably bad and needs to be replaced. This is possible to be done by you but I like when they do it, any thing happens you have there insurance to make repairs and be responsible for property damage.
Apr 23, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
Bosch dishwasher shx46a06uc-30
the unit will try to complete the last command it was engage in before it went in the overfill safety mode. you must perform a cancel drain cycle to reset unit to default setting. Remember the drain cycle is 2 min and must be completed to reset main control. however if it went into a overfill status you have a leak and it generally comes from the pressure chamber on the lefthand side of unit where the water enters tub
Apr 17, 2012 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher is reading "overfilling", but no water is in unit. Door can open, noise of motor or pump continues and will not shut off even with the Power switch. Only way to stop noise is to turn off the...
HI- The flood switch has been tripped. It is located under the unit and is not really accessible except by a Tech. The most likely cause it poor draining; if there is a little water left over from each part of the cycle then eventually the water will overfill into the pan under the dishwasher and trip the flood switch. Check the Air Gap on your sink for blockage if you have one and check the dishwasher filter inside the unit. You can just let it sit for a few days or a week and the water in the pan will eventually evaporate and the switch will remedy itself, or you can call a Tech and have them dry it out and check the drain function. Hope this helps, good luck.
Sep 24, 2010 | Asko 24 in. D3530FI Built-in Dishwasher
D3350 F4 indicator
F4 This is a Fault with the water fill
Note: Lights blinking, pump running and controls dead indicates an over fill fault
1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find that it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. The drain hose must run up to the top of the underside of the counter top then down to the drain. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
Aug 05, 2009 | Asko Dishwashers
I have a kenmore dishwasher. While it was in the
hi...
If the cycle doesn't complete, check these....
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
if still it doesn't fix your problem then see whether any error codes are generated....
F1 Water heating fault, selected temperature not reached within 60 minutes · Incoming water temperature too cool
· Heating element burned out
· Thermostat defective F2 High water level · Plugged/Bad water pump
· Defective water inlet valve F3 Thermistor fault · Open thermistor
· Bad wiring to thermistor F4 Fault with water fill (only on machines with level-controlled fill)
Note: Lights blinking, pump running and controls dead indicates an over fill fault 1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray
*Faults may vary by model. Use this as a general guide.
i think these details would definitely help you.....thank you...
Jul 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwasher keeps tripping electric
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwash
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Jan 04, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Asko dishwasher
You could have a bad fill valve that doesnt close. Try unplugging the unit or turning off the power at the cuircuit breaker. (not the power button) If it still fills when you turn on the water, it just has a bad fill valve. If it does not fill, take apart the door and check for broken wires at the lower left corner and see if the wiring is shorted together. If it is not, you may have a stuck relay on the control board. Sometimes those realy stick, and if you can get to the board (located in the upper left corne of the door) you can tap on the relays with a small hammer or screwdriver handle one at a time (with the unit unplugged!) and some times they will unstick and be fine. Very low tech, I Know...but you are trying to avoid a board replacement. Good Luck!
Oct 21, 2006 | Asko D1776 Built-in Dishwasher
Asko D1776 Built-in Dishwasher Logo
107 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
