Question about Epson TM-T88III (C420863)
DOOR DOES NOT OPEN
SOMEHOW THE DOOR GOT STUCK AND DOES NOT OPEN. WHAT COULD BE THE PROBLEM
  • 34 Answers
Remove jammed paper by opening the cutter cover and turning the know until you can see a triangle. remove the jammed paper, once remove you can now open the paper journal cover.
Posted on Dec 22, 2008
2008 Hyundai Accent 2 door hatchback- passenger door is stuck and won't open from either inside or outside. What can I do without paying a lot?
Unfortunately not much. If the door will not open from inside/outside, it will most likely be a lock issue. In most cases, the door will need to be disassembled for access to the interior components. The door is not designed to be disassembled while closed. If put into the wrong hands for disassembly while the door is closed, you most likely will end up with interior panel damage which could cost more to repair/replace than having a pro complete the repair fist hand.
Mar 07, 2016 | 2008 Hyundai Accent
How to open a stuck door on 96 chevy 1500
A mechanics worst nightmare. You have to somehow remove the door trim on the inside to get to the latch and lock mechanisms to release them manually to open the door. Hard to explain but thats basically the idea. Keep in mind that there are probably plenty of replacement door trims in the junkyard so don't be afraid to damage the one you have to gain access.
Aug 30, 2014 | 1996 Chevrolet K1500
My garage door opens when the neighbor opens his garage door
somehow his controller has "grabbed" your frequency which you already know, you cant change the frequency of you garage door receiver. what you do is unplug you opener and have him reprogram his remote to his door while your receiver is incapable of being programmed. somehow your receiver was in program mode when he set his door opener up. at the back of your opener there should be a red button that allows you to program new receivers, make sure this isnt damaged or stuck while pushed in. i have tried these ideas with some success.if this doesnt work then try reprogramming both yours and his from scratch, one at a time while the one not being done is unplugged. hope this helps
steve
Nov 07, 2013 | Overhead Door 109130-390 390 MHz...
The ice chute door (flap) is not opening. Is it supposed to open from the weight of the ice dropping on it, or is it somehow connected to the ice lever in the door when you push on it?
Most Ge refrigerators have a solenoid that is in the door that opens the ice dispenser door. It activates when you push the lever it activates the micro switch. Then sends the signal to the board that sends power to the solenoid and opens the flapper door. Most times the solenoid is either rusted or stuck. You can get part at local appliance parts store but it gets involved to take door apart to repair if one has never done it before. As always if you are not comfortable trying the repair please call a local service technitian.
Nov 12, 2010 | GE GSS25LGM Side by Side Refrigerator
Somehow my garage door Sensors (at the bottom of door opening) had debris which caused the Sears Door to go down and then go back up. I carefully removed the debris and now the door is stuck in the down...
There isn't a way to bypass the remote. If you call out a door technician he can drill a hole in the door and use a tool to pull the release handle. They can then install an emergency release using the hole they drilled. This will prevent the problem you are having in the future which is not as uncommon as it may seem Every time you have a power outage you are unable to get into your garage.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
The driver door on my 2004kia optmia wont open.
If you have tried the inside, and outside door handle, and it does not open you need a new door latch assembly.
Jul 11, 2009 | 2003 Kia Optima
Oven door open
Turn the operating mode dial to self-clean, then manually hold in for about 20 seconds the light pin on the oven rim. The lock will eventually open after 20 or so seconds. Turn off the operating dial and the door will close.
Jan 12, 2008 | Ovens
DVD stuck in DVR5000
Some CD/DVD units have a manual opening mechanism, it looks like a small hole on the front of the unit, try using a needle or a metal rod that fits by inserting it into the hole and pushing it should open the unit in case it got stuck somehow. If afterwards it continues to work then all's good else you'll have to bring it to a workshop.
Nov 19, 2005 | Rio DVR5000 DVD Player
Epson TM-T88III (C420863) Logo
139 people viewed this question
Top Epson Televison & Video Experts
janman
Terry Dovre
Terry Dovre
Are you an Epson Televison and Video Expert? Answer questions, earn points and help others
