Question about Nikon D300 Body Only Digital Camera
Battery remove I can open the door, but how do I slide out the battery? The top of the battery is flush with the bottom of the camera inside the battery compartment, and I can't grab it to pull it out.
    Problem Solver:
  • 12 Answers
Can you not hold the camera upright and it should fall a little bit to allow you to grab hold of the end and pull it out.
Otherwise it this isn't happening there may be a mechanism problem.
hope this helps.
Drew
Posted on Nov 17, 2008
Removing battery
The battery door is on the bottom of the camera. Hold the camera bottom up with the battery door to your right. Slide the oval spring-loaded battery latch all the way to the right and gently pull up on the battery door.
Mar 20, 2014 | Nikon COOLPIX L6 Compact Digital Camera...
How do I open the battery door?
With the display screen facing you, look on the bottom right for the door for the batteries. There's a tiny grey slide switch on the right side of that door with polk-a-dots that you have to slide toward the screen side of the camera. Hold the camera upside down and while sliding this switch away from you, you can slide the door to the right, which opens the battery compartment.
Jan 19, 2013 | Nikon Coolpix S30 Digital Camera White
Can't open service door
HP Support > Probook 4530S Notebook PC > Manuals > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=5060880#1
Under the bold subheading -
Service and maintenance information -
Click on -
HP Probook 4530S Notebook PC and HP Probook 4730S Notebook PC - Maintenance and Service Guide
Bottom Door - Page 49
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Position laptop bottom side up, Battery Compartment facing you.
3) Remove the Locking Screw if installed.
(Area where Battery Compartment meets Bottom Door, and in the Middle; is screw location)
4) Slide the Bottom Door release latches to release the door.
(One latch on each side of Bottom Door; where Bottom Door meets Battery Compartment. The Latches slide to the INSIDE of the laptop)
5) Slide the door towards the Front of the computer, and lift off.
(Front of computer is AWAY from you. On the opposite side of the Battery Compartment)
Regards,
joecoolvette
[ P.S., you remove the Bottom Door; you wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; or you risk using the laptop for a Frisbee from now on, or a doorstop.
Average cost is around $3 to $6 ]
Nov 06, 2012 | HEWLETT-PACKARD Probook 4530S 156 I52410M
Do you change the batteries
Open battery door on bottom of camera (little plastic slide latch with the words "BATT. OPEN" next to it). Batteries will fall out into your lap. One will roll off onto the floor and end up under some inconvenient piece of furniture.
Replace with Alkaline AAs according to the polarity ("+ -") diagram printed on the bottom of the camera, and molded into the inside of the battery compartment lid.
Oct 15, 2009 | Canon PowerShot A75 Digital Camera
The Battery Door on my Sony Cybershot DSC-S40 won't open.
No easy solution except:
1. Remove all 3 screws from body.
2. Carefully wedge off the back half of body.
3. The back half is connected to the front half by a small cable. Don't break this!
4. The door has a hinge pin. Wedge up and remove this pin.
5. With small screwdriver, wedge off the door from top. Should pop out.
6. Apply small amount of oil on sliding areas.
7. Reinsert door. If still stuck, see step 5.
8. Reassemble camera back and screw down.
9. The reason for sticking is unknown, but door can still be removed by popping off as in step 5.
Nov 08, 2008 | Cameras
The date and time will not save on my canon powershot a560 when it is turned off and on.
Open your battery door. Notice inside that there's a little slide door inside labeled CR1220. Pry open this little slide door and remove and reinsert the encased watch battery (this battery powers the camera's clock). Removing and reinserting might fix it temporarily, but more than likely this battery is getting very low. Recommend going to your local drugstore's battery section and buying a replacement CR1220 battery. They're very common and inexpensive (a few bucks).
Sep 01, 2008 | Cameras
Disney princess camera
trentshoffne,
bottom of camera open battery cover with a pen point, insert one AA battery close cover.
film door is opened with pen point left side of film door. load film & bring film leader to take up spool, close film door. rotate advance to # 1 counter on bottom.
turn camera on with sliding switch on front of camera, this opens lens cover and turns on flash .( if wanted ) second click.
at end of film roll pull rewind lever up and rotate clock-wise to rewind film.
open film door and remove film.
remember to turn camera off when not using.
Aug 05, 2008 | Photography
Battery cover replacement for the Dimage Z2
to get to the battery door you must remove the back, to remove the back you must remove the top of the grip (shutter button and dial and WT lever). remove top of grip... 1) starting at the bottom of the plastic strip (along the front edge of the grip) that holds the shutter button, slide upward, the strip will bow outward and after about 3/16", the bottom's free. the only other thing holding it in place is a bit of double-stick tape and a similar clip at the top. CAREFUL! there's a spring under the button that's easy to lose. 2) Inside the battery case, front battery, all the way at the top, there's a tiny phillips screw, pull it. 3) peel away the right side rubber grip right by where your thumb meets the W on the W/T lever. 1st hole you'll see is a springy clip, keep going around to the right til you find a screw. pull that. 4) back to the springy clip hole, pushing inward on the finger, the top will come off straight up. leave it hanging, you just need it out of the way so the back can come loose. remove the back... 5) bottom of camera, remove 2 screws nearest the CE label and one outboard of the rearmost battery. 6) viewfinder cap: 4 screws, skinny on top, fatter on the bottom. the cap pops off. 7) lcd cover/frame: pull away from viewfinder(top) edge about 1/4 inch. the bottom's held by fingers; they need to slide to the left 1/8", then that's off. 8) remove screw @ lowerleft of lcd. now the whole back will slide rearward. 1st thing loose is memory door, remove it. slide the back off, out of the way. you'll now see that the battery door is held on by two hinge pins, not one continuous. the rearmost pin will slide left into the memory cover area, and the door will flex enough to remove it toward the front. trickiest part of reassembly is the spring under the shutter button. balance the spring on the camera, put the button into place. hold it in place with the screwdriver through eye of plastic strip, leaves plenty of room to seat the strip. lose a screw? I did, and the least-needed one is the one pulled at #3. NOW who needs to buy a battery door? I have a z3 with a fried power board.
Mar 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Replace Battery Cover
Oct 04, 2006 | Konica Minolta DiMAGE Z1 Digital Camera
Nikon D300 Body Only Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
