Question about Konica Minolta DiMAGE G530 Digital Camera
I dropped my digital camera when it was opened and it is jammed open, I had power at first, but then I took the batery out and put it back in and have now power. I cant get it to close. What can I do to repair it?
I have the same problem exactly. After my 3 yr old daughter brought it back to me after she had bounced it off the floor a few times, the lens was half out with the last pic taken on the display. I couldn't do anything so i removed and reinserted the batt and now i have a sticky out lens and no power...
Posted on Jun 04, 2007
SOURCE:
Camera is stuck in open position
Pull the battery out and put back in then power on the camera should stick out then when you turn it off should go back in.
Aug 28, 2012 | Olympus Cameras
We took a few pictures the night before we went to a museum. That night we put the battery for the camera in a charger that plugs into an outlet. This batery was taken out of the camera. The next...
Cushioned or not, your camera likely landed on the end of its lens, dislodging it from the track it rides on to zoom, or jamming it on the track so that it cannot move, and the camera powers itself off to prevent further damage when it senses the lens problem. You can try a home remedy by powering the camera off, and then holding the zoom button while you power up. Sometimes that will pop the lens back on the track and restore function. You can also try GENTLY pulling on the lens while you power the camera on (or GENTLY pushing if the lens is extended). Some owners have reported success by GENTLY tapping the lens end on a firm surface, but that can also cause more damage. If all else fails, you'll need to get a repair quote (NOT an estimate) from Kodak.com or your local Kodak repair point to decide whether or not the camera is worth the cost of repair (some repairs can exceed the cost of a new camera).
Jan 18, 2011 | Kodak EasyShare P850 Digital Camera
I dropped my Nikon Coolpix S3000 camera and now the lens is jammed I tried to push it back in so it wasn't on an angle but now its stuck completely in and its all blured if I took it apart could i...
your best bet is to gently wiggle the lens - try to open it and assist it to open - try to close it and assist it to close - a drop or two of electronic such as Max Professional Electronics Lubricant for Electronics - Amazon.com for about $10. and repeat to assist it along...
Nov 03, 2010 | Nikon Coolpix S3000 Digital Camera
Camera dropped. lens is stuck in open position, won't turn on
Hello
Thank you for using FixYa for your problem
Zoom lens is jammed, It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Jan 20, 2010 | Cameras
Lens Stuck open on Mz67 hp camera Error code Mz60-022
Was this stuck fully open or was the lens partially opened, or was the lens jammed?
The lens can be removed and replaced with another lens from another non-functioning camera (See ebay). The lens component can also be dissembled. Putting the lens back together is tricky because the parts have to be aligned just right for the lens to work. If working with a Jammed lens, extra care has to be considered not to break any of the moving plastic parts of the lens or that part (if not entire lens) is junk.
With the motor detached from the lens, the lens should extend and retract freely. Use this to test the lens when you dissemble the camera. Be careful of the flash board.
Mar 15, 2009 | HP Photosmart MZ67 Digital Camera
Camera does not respond
I suggest you open the battery compartment and check the connections on the battery. It may be that they are a little dirty, preventing proper electrical connection, in which case you can clean them with a little cotton bud and perhaps some methylated spitits.
Mar 15, 2009 | Casio Exilim EX-Z50 Digital Camera
I can't turn my camera on????
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera won't work after being dropped in toilet
http://www.fixya.com/support/r3771170-phone_water_damage
Oct 07, 2008 | Kodak EasyShare Z730 Digital Camera
Cannon Power shot SD630 Lens Problem
Sorry to here that you can send it to a repair company like me for repair. cost about $120.00 plus shipping to fix.
Feb 26, 2008 | Kodak Easyshare M753 Digital Camera
Konica Minolta DiMAGE G530 Digital Camera Logo
29 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
