I have a Baxi Combi boiler and want to add new TRVs to the radiators. Do I need to drain the system or can just turn off all the radiators and hope not much water escapes. How do I add new inhibitor if I have to drain the system. Any help will be gratly appreciated
  • hirot Nov 10, 2008
    Sorry this didn't really answer my question about is it neccessary to drain the system. I have worked out about the auto feed and now how to add inhibitor.
    Thanks for trying though
  • hirot Nov 11, 2008
    Again many thanks for your help. I can turn off the mains feed but I guess the the real question now is do I really need to drain the system or if I work on one radiator at a time, turning one valve off, will much water come out when I swap the other valve.
    Regards Hirot
  • 1,420 Answers
You will need to isolate the boiler from the radiators because there is an auto feed valve that will continue to allow water into the system if the pressure in the boiler drops. There should be some valves off of the boiler that will allow you to do this.
Posted on Nov 07, 2008
  • Chandler Ede
    Chandler Ede Nov 11, 2008
    You will need to isolate the boiler! The inhibitor is only a quart or two of fluid, either pump it in using a pump and garden hose or use a funnel and hose and pour it down the pipe as you replace the radiator valves with TRV's.
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Nov 06, 2012 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
Dec 26, 2009 | Desa International CBN30T Central Heating...
How do i drain my system i cant find a valve on any of my radiators its a combi boiler is there a draining system on the boiler
some boilers drain via the emergency relief valve [usually a spring loaded red knob to twist or a lever ] others have a small drain tap under the boiler just poking out of the base plate. Remember to turn off the mains input.
Oct 10, 2009 | Water Heaters
Water gets hot then turns cold and runs cold then hot again
Secondary heat exchanger is blocked on sealed system side.
Remove and de-scale heat exchanger or fit new one.
Feb 04, 2009 | Combi Centre DX - Mango
Combi Boiler pressure gauge reading 0, and radiator half on!
The first thing you need to do is to put some more water into your heating system. This is usually done by allowing water from your (pressurised) domestic cold water supply to flow into the system: On older boilers, this is done with a connection (often made with a removable hose) on the pipework just outside the boiler. Newer boilers may have a built-in connection with some sort of removable link (sometimes looks like a plastic key).
Once you've got the boiler up to working pressure (typically about 1 bar - 15 psi), you should be able to bleed your upstairs radiator properly.
This may be all it takes, though the pressure excursions you're getting when you run the hot tap suggest there may be another problem. See what happens to the pressure as the boiler heats up and cools down. There really ought to be very little pressure difference between the two conditions. If you see significant changes, this usually means that the "pressure vessel" (or in hydraulic terms, system accumulaor) has lost its air charge.
The pressure vessel is a metal container inside the boiler, usually painted in red enamel. Somewhere near the top, you will find a schrader valve (like the one on a car tyre), and you can use this along with a tyre pump to replenish the air in the top of the vessel. This will reduce your pressure transients for a while, but you need to keep an eye on it. If the problem returns, you probably need to replace the pressure vessel (or clag another one into the plumbing alongside the boiler).
A.
Feb 03, 2009 | ACCO Brands Water Heaters
All my radiators dont heat up
I must go to bed now but you may want to try going to http://en.allexperts.com/q/Heating-Air-Conditioning-696/2009/1/COLD-RADIATORS.htm
to see if this helps!
Hopefully someone else at FixYa will help you while I'm sleeping!
Good Luck!
0dc2daf.jpg jackiaria
Jan 31, 2009 | Combi Centre DX - Mango
Our Baxi combi 130 HE heats the water OK but will not heat radiators. This has happened after a period of not using the radiators (ie. over the summer)
check the pressure it should be in  the green band, check the pump, inside the boiler cabinet lower right.
Oct 29, 2008 | Heating & Cooling
Heating & Cooling Logo
120 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
