Question about Panasonic (CFP1P3CKK6M)
Need help. I have a panasonic model SA-DK10,it wont read disc anymore,the screen says DVDHO2 and than says no disc.and a weak latter it suddenly turned off and I cant turn it on. there's no power.can you tell me what part to order.
0 characters
1 Points
My hp wont read dvd-rw. am i not using right type of disc or what could it be.
first is check if dvd or just cd rom u have..if its is cd rom definitely you cannot read any type of dvd disc.if it is a dvd rom, how old is you dvd rom?all dvd rom even cd rom even its is a writer or reader only have limitation on the lens usage.maybe it reaches the limit of usage.if thats the case you have to replace or buy a new one..
Jul 11, 2011 | Barcode Scanners
HL-DT-ST RW/DVD GCC-4244N Will this burn a DVD ?
This model drive is a combo DVD drive.
It is a CD read/write drive and a DVD ROM drive (only read DVD disc but not burn disc).
Mar 31, 2011 | Barcode Scanners
WII system turns on and screen pulls up it just wont read the discs. dics are clean with no scratches.
A couple things could be happening.
Make sure you're inserting the disc properly as the Wii will accept the disc even if you put it in backwards. Make sure that the label side (the side with all the pictures) is facing toward the thin side of the Wii and the shiny side is facing the thick side of the Wii.
If that doesn't make a difference, then it's like a problem with the disc drive itself which can only be fixed by Nintendo or a repair shop. They'd have to take your Wii apart and possibly replace the drive.
Mar 25, 2011 | Barcode Scanners
Cd rom cant read the cd
If the disc rotates but fails to read or register any data, then you can try and do a good cleaning on the lens eye of the drive. if this wont improve then the drive needs a change.
Mar 02, 2011 | Barcode Scanners
Some of my keys on my laptop do not work the d,x,m,n,l,q, and enter there could be some others I might not know about. All of sudden they didn't work one day then they worked for a bit and went back and...
Take your computer to a qualified technician, for replacement of the keyboard.
Or, take a keyboard with a USB adapter, and connect it to a USB port on your computer, and use that keyboard, instead of the built-in keyboard.
Feb 21, 2011 | Barcode Scanners
I need the driver for Panasonic model SD-100A-U2 external optical disk drive
Please help me. cause I lose this driver
Oct 19, 2010 | Panasonic Barcode Scanners
HP dvd1040r (internal drive) Burns to DVD+R discs but won?t read any data after burn on disc. Why is this?
the problem normally occurs when the lens is becoming weak and the ROM is old. It sometimes does not burn correctly.The best solution is to replace the ROM
Aug 02, 2010 | Barcode Scanners
My son's psp (the older fat version) has stopped reading discs
Not sure is this actual PSP or play station. If it is Play station It is very possible that there is problem with laser that reads disks. Try to by PSP cleaner and run it and this might fix the issue.
Dec 29, 2009 | Sony ACY-BR81/OB
Psp wont read disc
your lasers Dirty or damaged.
These usually last about 14-18 months sometimes longer, depending on amount of use. ( operating hours ) your best solution, is to try blowing into the UMD Drive, may be lucky and remove a speck of dust. Or you,ll need a UMD Replacement.
Best-cheapest place is e-bay.
You,ll also get fitting instructions. Alternatively is to take it to a repair shop. But don,t expect much change out of £75.00.
Mike @ compurepair.
Mar 12, 2008 | Sony ACY-BR81/OB
PSP wont read games(UMD)
try reset default setting.  it worked with my psp.
Oct 08, 2007 | Sony ACY-BR81/OB
Barcode Scanners Logo
Top Panasonic Barcode Scanners Experts
Brian Sullivan
Brian Sullivan
Are you a Panasonic Barcode Scanner Expert? Answer questions, earn points and help others
