Question about Hoover Washing Machines
I have a hoover otsein OHNF 6117, set the program and the water does not go into the drum ..it pours out of the drawer...i have checked and there is no blockage..what is the problem ???
  • 641 Answers
SOURCE: Fabric Softner drawer
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water enterence and distribution to drawer's cells (following the programmed cycle)are done by a lever's movment (part of the dispenser). The lever movment is controlled by two solenoids that received their power from the timer. By openning upper machine's cover you will have an access to the dispenser. Dissconect the power cable from the machine before moving to next tests !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movment). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Jun 01, 2006
  • 30 Answers
SOURCE: Hotpoint WD64, leaking water from soap drawer
try turning down your cold water pressure. some times the pressure it is so great that the water hits the soap dispense and spill over. this is a common problem with front loaders??
Posted on Aug 15, 2007
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
  • 1003 Answers
SOURCE: hoover nextra wont fill
REPLACE WATER INLET SOLENOID
Posted on Feb 02, 2008
SOURCE: Hoover CA230 1300 Special Edition Washing Machine
I had the same problem. My husband checked the carbon brushes attached to the motor and ran the machine on spin. The brushes were sparking so he assumed they were worn and replaced them and hey presto machine works fine now. The brushes cost 23.99 and were just bought from a local shop but can be bought online cheaper. Hope this helps solve your problem. Essex
Posted on Apr 08, 2009
When we put the machine on a 90 degree washing cycle water and foam pour out from the detergent drawer
seems as if the water inlet from the detergent drawer to the drum could be clogged up might wanna have it cleaned or replaced
Jan 07, 2017 | Washing Machines
My washing machine is leaving dirty marks on my washing can you help?
Looks you have aleakage of grease form a damaged bearing in the drum.
If you have the technical preparation, you should remove the drum and check those bearing. See some interesting youtube videos about issue:
How to remove washing machine Drum tub 1 of 4
How to Replace Washing Machine Bearings
How to replace washing machine bearings on Candy Hoover Otsein Zerowatt
Dryer Repair Replacing the Lower Front Drum Felt Seal GE Part WE9M30
YOU EVEN MIGHT FIND MUCH MORE ON THEME DOING GOOGLE REARS ON
Youtube repair drum
Some other brands are similar to Hoover
Aug 22, 2015 | Hoover Washing Machines
My washer makes grinding sound when washing, how do I fix this?
Guess it's a bearing in the drum, though just my appreciation. If you are not a tech in washing machines, you should call a reapir service to get it dismounted and replaced
Watch some videos about issue. Take note that you are not specifying your make an model and procedure might be somwhat different for your particular washing machine.
How to change drum bearings on washing machine
How to replace washing machine bearings on Bosch Neff Siemens and some...
Aug 12, 2015 | Washing Machines
Water pouring out of the detergent drawer
Remove the dispenser draw and pour water down the soap chute as much as you can to soften any soap causing the blockage. When the water level drops, add more water. After a while use a soft flexible rubber hose and run it down the chute up and down to remove caked soap. Once this has been achieved, run the machine on "Rinse & Spin" to clean out the drum.
Mar 19, 2014 | LG WM2101H Front Load Washer
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Hoover ws130
take out the detergent drawer and thoroughly clean. if that doesn't work, the may be a blockage in hose from drawer to tub. take off top, remove hose and clean out
Mar 03, 2007 | Broan-NuTone WS130 Kitchen Hood
Washing Machines Logo
135 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
