My zyxel router used to work on my PC, all my laptops, my ps3 and my wifi enabled phone. but when I went on the Pc and my mum went on the Laptop it wouldnt connect.It only connected to one thing at a time. a man came to fix the problem and when he was away I found that the problem persisted and not only that it wont connect to the ps3 or my phone at all now. Any Help or suggestions
    Scholar:
  • 132 Answers
You may reset the router and configured it anew.
You may also do a firmware upgrade for your router.
Hope this helps!
Posted on Nov 10, 2008
Error 8001000A IN MY PS3
hi,
you don't need to connect the router to ps3 configure it one one pc/laptop then activate the wireless on the router,then setup the wireless connection on ps3.
Apr 07, 2014 | Zyxel Computers & Internet
My compaq presario v2000 laptop cannot detect the wifi signal of Zyxel router. It can detect all other router brands. I'm sure that my Zyxel router is sending signal because I can detect it using my...
I would guess that all the other wireless routers are broadcasting using the G wireless standard 802.11g and your router is only broadcasting using the newer N 802.11n standard. Your laptop only supports B/G. Check your settings on your router and either change it to G or dual G/N mode so your older laptop can find the network
Sep 17, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Bought a new acer 5750 laptop (i5 2nd Gen, 6GB RAM) which connected intermittently to my router. PC World phone help worked through network adapter enable/disable and then eventually a full default...
I would try:
1. updating driver
2. try connecting via Ethernet, if the issue is only wireless connectivity, try using a USB wireless network adapter, if that works means your lappy has a bad built in network adapter.
3. Are you locating laptop too far from router?
Good luck.
Mar 09, 2017 | Acer Computers & Internet
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
Won't recognize home wifi, though it does recognize cafe wifi
Check the settings on your router, make sure it is transmitting 802.11b AND 802.11g. Perhaps your previous laptop is accepting the signal that is possibly 802.11g, but the older laptop is needing b. If that doesnt work, go back to the cafe, and see if you are still able to connect. If not, check the settings to make sure wireless is still enabled. Some laptops have a slider button on the front or side to enable/disable wifi, one of mine has it and sometimes i accidently turn it off. If it is indeed on, try disabling it, and re-inabling it.
Sep 11, 2009 | Dell Latitude C400 Notebook
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
Modem router
I can tell that your network topology is not the most complicated ever.So u ve got 3 terminals,1 desktop pc and 2 laptop.Simple,reset your zyxel(from the button on the back) and reconfigure the Local area interface connection(ip & subnet mask for the zyxel),reconfigure your internet connection,(WAN zyxel interface) in case the zyxel is your Internet gateway too.Third,make sure NAT & Firewall are up and running(usually are by default) Finally,reconfigure the WiFi interface with the correct SSID name & WEP key or whatever security you prefer.Write down the security pass for your wireless and you are done.Good Luck.
Apr 19, 2008 | Zyxel Prestige 660H Router
Zyxel wireless router(p-660hw-t1)
Change the MTU size to your ISP's default!
Jan 14, 2008 | Linksys Wireless-G WRT54GX Router...
WiFi not recognized on Compaq laptop
this can happen sometimes, just go to network connections in control panel, right click on the wireless icon and click dissable (or press the rellevant button on your notebook) Restart pc and then right click on the icon again and select enable. There should be an icon in your taskbar, right click and select view network connections, and then see if your router is listed and click connect.
Sep 25, 2007 | NetGear WGU624 Router
Computers & Internet Logo
David Payne
David Payne
