Question about Microsoft Office Professional 2007 Full Version for PC
Printer not responding...
I try to print and get the message "printer not responding..." . I checked the connection and everything is well connected. What should I try now? Thank you so much for your help... Cati
    Scholar:
  • 83 Answers
Try to check your setting for the printer before printing. maybe you have paper jam try to check feed papers. press the power if this is blinking. If the problem persist just restart your computer. Sometimes thist problem needs restart to continue printing.
Posted on Nov 09, 2008
Everytime i go to print something it says "printer not responding" the status shows online, and turned on. I put the disc in again to try to install it and it dont even pop up on the computer?
If your printer fails to respond to a job, check that all printer cables are connected properly and be sure that the printer is turned on. If everything is connected properly and powered up, go to the computer's "control panel" from the "start" menu. Choose "printers" and be sure that your printer is selected as the default. If everything checks out in the control panel, right click on your printer icon and select "properties." Click on the "details" or "port" tab and make sure that the correct port is checked off. Next, double click on the printer icon, which will bring up a list of current jobs in the print queue. Cancel all documents and try printing again. If your printer is attached by USB port, you may try connecting to other USB ports.
Good luck, KoBaC
May 22, 2011 | Computers & Internet
My printer model is Canon Mp250 all in one printer my problem with the printer is that everytime i print a document it always says printer is not responding, I check all the connections its all connected,...
Hi
Try to restart the print spooler service. Here is the link http://www.fixya.com/support/r8758623-check_fix_print_spooler_service_causes.
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Apr 09, 2011 | Office Equipment & Supplies
Hi, I have been using a Kodak ESP 5250 for a while but have just tried to print a doc. and have ' Printer not responding '. Checked for connection, paper, ink, reset everything but the page is waiting in a...
Hello and Welcome to FixYa!
The "Printer not responding" message may appear due to many reasons like;
  • Bad connection
  • Printer Malfunction
  • Bad Communication port
  • Faulty Drivers
  • Printer Spooler not active
As you have stated you have had checked the connections, and also have reset the printer, so going straight to Drivers and Spooler issue.
I'll advise you to navigate to this link, detailed step by step guidelines are mentioned there; Vendor's support page. (Step 5)
If you are on MAC OS-X, this is the support link.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Feb 06, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
The printer is not printing any document
Hi
Please check
1. Do you have a printer cable failure?
The printer will not be printing if its not connected to the computer. Check that the printer cable connecting your printer to the computer is firmly attached at both ends. Apart from this cable, there should be one more cable which is the one connecting to the wall outlet.
2. In case it still not work after checking try resetting and printing.
3. Else please change the Data Cable if it is very old one.
Jul 22, 2010 | HP LaserJet 1300 Printer
We have giant company & having CANON LBP 2900.Whenever i am going give print it,s not printed .message shown ready to print but error occuring please help
try checking the printer if it is installed properly, by going to the printers and faxes folder, right click lbp2900 and check its properties, verify if the port used is correct. check printer if it is online and also the usb connection. if everything is ok, try replacing the usb cable. if after replacing the cable and the printer still doesn't print, uninstall it and remove the connection. Restart the computer and begin installation, do not connect the printer unless the system prompt you to do so. Run test print after the installation.
Jun 22, 2010 | Canon LASER SHOT LBP-2900 Printer
HP PSC 1510 All-In-One-Printer not responding
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printer not responding to my mac when i press print. the print window comes up but in the message it says printer not responding
check your printer cables if its properly connected and also make sure that your printer is on
Mar 11, 2008 | Computers & Internet
Printer won't print in some softwares but will print in others.
Hai
pls reinstall the os and try it will work otherwise there is problem in printer port pls check the setting it will work
Oct 25, 2007 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
