Question about HP Officejet 6310 All-In-One InkJet Printer
Cannot get it to go online
Wireless - printer was working fine - I moved - had my cable come in and hook up my cable / wireless ( Roadrunner ). Now I cannot ger my printer on line. Tried connecting it w/ a usb cable - still cannot get it to go online.
    Novelist:
    Scholar:
  • 125 Answers
I'll try to help but just to let you know I don't have a wireless Roadrunner. I'm just guessing your printers is programed to go wireless and you may have to reprogram it to recognize the USB cable. Hope this helps.
Posted on Nov 12, 2008
Ok.....my internet is up and running......and im useing the SB5101 Model...but when i switch it back to my SBG900....it gets stuck on the roadrunner (internet provider) web page.....it works fine with the...
Turn the cable-modem off.
Unplug the AC poewr to the cable-modem.
Turn the router off.
Unplug the AC power.
Reconnect the AC power to both the cable-modem and the router.
Turn the router on -- this off/on sequence should "reset" the cable-modem and the router.
If the router still does not work, replace it.
If the cable-modem does not work, get RoadRunner to replace it, if they want to keep you as a paying customer.
Jun 26, 2011 | Arris SURFboard SBG900 Wireless Router...
Is there a way to set up my Lexmark x5650es so i do not have to use a usb cable?
This printer comes with a Inbuilt wireless port and alsoa ethernet port. You can either configure it to be used with your Wireless router and make this a shared device or you can connected it to your router using a ethernet cable and then you can access it over your network. Assuming you have a wireless router and the expertise to configure a wireless printer. If not consult the user manual.
Please rate if helpful.
Thanks
Apr 13, 2010 | Lexmark X5650 All-in-One InkJet Printer
I loose internet everytime the phone rings
Absolutely. Wireless LAN is on 2.4GHZ. You will want to get a phone at a different frequency.
Apr 05, 2009 | Belkin Computers & Internet
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Linksys wireless was fine on my lan line now cable it is not?
Lets see if this works out for ya.
1. In your browser go to http://192.168.1.1
2. The user will be "admin" and the password field leave it blank
3. Go to the Setup Tab
4. On WAN Connection Type make sure it is set to "Obtain an IP Automatically"
5. Go to the DHCP tab and make sure it is enabled
6. Unplug the Roadrunner modem and the Linksys Router.
7. Wait around 15-30 seconds
8. Plug the Roadrunner modem in and wait until all the lights except the ethernet/computer connection are on.
9. When they are all on plug the Linksys router power back in
10. Wait around 30 seconds and see if your getting a connection
Otherwise get back to me. Good luck.
Jan 30, 2009 | Linksys Wireless-G Broadband Router
Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Changing from DSL to Road Runner Turbo
I'm sorry to say but you cannot bypass the modem capability of the DSL Westell Modem/router because that is really made to function as a DSL modem and a router at the same time, so the best way to make everything work here since you change from DSL to Cable internet just need to get a wireless router like a Linksys WRT54G that can make everything work again like before.....
Nov 05, 2008 | Westell Wirespeed VersaLink...
Help!! I'm having difficulty setting up my wireless connection to my ibook!
Last time I checked Roadrunner required you to have them set up the router. However, you should have an existing router from Roadrunner all set up. If you connect your other router which has the wireless capabilities to that then you will be able to use your wireless. Otherwise you will need to call Roadrunner and have them do some configuration on your device.
May 29, 2008 | IBM Computers & Internet
WIRELESS ROUTER
If you mean by the roadrunner that you are connect via a cable, the reason why the signal may fail and stop you from watching streamed video is that wireless is only 54mbps and not the best speed for streaming, but wired streams at 100mbps and is constant speed whereas wireless doesnt give a constant true speed of 54mbps it can reduce considerably.
Aug 05, 2007 | Belkin (F5D5231V4-SN-PD) Router...
HP Officejet 6310 All-In-One InkJet Printer Logo
57 people viewed this question
Ben Johnson
