Question about Epson ACULASER CX11NF All-In-One Printer
Develper Does the epson printer have seprate developer or is it mixed in with the toner. If it is not mixed in where can I get developer?
    Scholar:
  • 78 Answers
The answer to you question is "no". Epson printers do not have developer units mixed in with the toner. They are a seperate unit all together. If you look around, you might find an epson warranty service agent who is happy to sell you the developer, however dependant on the unit, they are fitted in variouse ways and may require some technicle expertise to install.
Gremlin11
Posted on Dec 10, 2008
Empty Developer on MP1900
Should replace the TYPE 28 DEVELOPER every 60,000 pages.... this is needed to mix with the toner. if you cleaned the toner/ developer mix out of the developer already then it will definatly give you blank pages ..... hopefully this helps.
Mar 13, 2014 | Ricoh Office Equipment & Supplies
Konica bizhub 211 maintenance developer
Yes you normal replace the developer and the drum at the same time. Developer is substance that will mix with toner to get the toner to the drum. It is not toner.
Jan 02, 2014 | Minolta Di351F All-In-One Printer
Bizhub 250 toner recycling
Toner recycling mechanism is located on the drum unit
The Cleaning Blade pressed up against the surface of the Photo Conductor scrapes residual toner off the surface. The toner is then conveyed by the Toner Conveying Rollers 1/2 to the Recycling Duct and eventually back to the Developer Mixing Chamber.Since the toner is thus recovered back to the Developer Mixing Chamber, there is no Waste Toner Bottle mounted in the machine.
Feb 23, 2012 | Minolta bizhub 250 Black and White Copier
I have Epson Color laser printer CX11NF. It's developer toners run out and I need to purchase developer toners. But the whole colors of Epson products are more than 500.00 USD. I have to find...
Well, just googling for "epson cx11nf toner" gave me several results.
I personally like lasertechservices.com service and prices. They have "compatable" Epson cx11nf cartridges for $30.2 (black) to $33.95 (Cyan, Yellow, Magenta). If your a little more technically skilled, they also have toner refill kits for your printer for only $93.95 (all 4 colors, includes reset chips). Some printers don't allow you to "refill" the starter toners that came with it, so you may need to buy the cartridges the first time around (ask them, they will know).
I only mention the above site because I have used them myself for my printer(s), but there are many other companies doing the same thing. Try to choose a supplier with good technical support, in case you happen to run into any problems (as in, do they have a phone number to call, because "email only support" sucks).
Jun 16, 2011 | Epson Aculaser C1100 Printer
Minolta EP2010 CSPro copier: Where does the develper bottle go??? I see the Toner MT 102a bottle but where does the Develper bottle install. Or does the toner bottle already have the develper filings?
When the developer is added during normal replacement, the developer bottle is installed in place of the toner bottle. Then when the F8 mode is initiated from the service mode the developer is added into the developer unit and automatically calibrated. This is only done after the old developer has been cleaned from the DV unit.
The toner bottle contains no developer. The developer is replaced separately and only needs to be changed about every 80,000 pages.
Good Luck and Thnak You for using Fixya.
Sep 21, 2010 | Minolta Office Equipment & Supplies
Need to know when you replacng ink cartridge do you turn left or right ... 90 degrees or 180... printer isnt detecting new towner
are your prints light? you may need to have developer installed by technician, toner mixes with developer, if developer is bad will not recognize toner
Jul 16, 2009 | Toshiba e-STUDIO 28 Printer
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Adding developer to sharp sf-2025
Hi, it means the developer requires changing. it has a life of 30k (i think). I would suggest that if your quality is not effected, then keep using the machine, or spend the money on an engineer to come out and replace it.
Andy
Feb 28, 2008 | Sharp SF 2020 Copier
Xerox work centre xl2130f developer
It goes in with the toner. The developer and toner mix in the cartridge. Empty the old out and put it in with the toner.
Good luck.
Feb 07, 2008 | Xerox WorkCentre XL2130f Laser Printer
Epson ACULASER CX11NF All-In-One Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
