Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water not coming out
The water stopped coming out - I push the lever, but nothing; however, the ice will still come out... I didn't know if it was a dirty filter; however, I don't even know where it is located or how to fix or replace anything... Please help...
    Problem Solver:
  • 18 Answers
Without knowing the model # filter is usually located on bottom of fridge in grill. When you depress the lever listen for the water valve in back of fridge to click on if not you may need a new water valve. What is the age and model # of fridge?
Posted on Nov 14, 2008
Ice maker stopped filling to make ice ,changed filter , still not filling with water
Have you checked the tray lever; when the tray is full with ice it pushes the lever 'UP' and sometimes it stays there.
Jul 25, 2015 | Refrigerators
Water dispenser ice maker
If you check the backside of your refrigerator...
There are TWO (2) different electric water-valves...
A generic WHIRLPOOL part number = wr57x10032
(typically you can hear the "THUMP" when the are working...
WATCH this attached video...
http://www.appliancepartspros.com/ge-water-inlet-valve-wr57x10032-ap3192626.html
Hope this is helpful...
Carnac the Magnificent
Dec 07, 2017 | General Electric GSH25JSXSS Stainless...
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Connected water supply and confirmed good water pressure. cannot get water to dispense or icemaker to make ice.
Hi, When you push the water switch in the door, do you the inlet valve humming? Is it possible that the wires came off the inlet valve?
If you remove the inlet valve from the cabinet and unhook the large size tubing that leads to the water dispenser, you can engage the dispenser lever in the door and see if water comes out.
I hope this helps you. Please let me know if I can assist yyou further.
Vic
May 31, 2009 | Refrigerators
GE Side by Side Refrigerator dispenses ice but no water
if the light is not coming on i would say that board needs replaced and it just pops right out
Mar 16, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
134 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
