Question about Acer NSK8458AN Keyboard
Acer aspire 7100 continually beeps while starting up
From 3 seconds after pressing the start button the laptop continually beeps and fails to start up. If I press Ctrl + Alt the beeping stops and Windows continues to load. Sometimes the laptop will load programs normally but sometimes it will load and run the wrong program. Example: Double clicking on Ms Word will load and run Ms Excel. Pease Help.
  • Anonymous Mar 25, 2014
    after playing with upper function buttons (shop, email, volume, etc) my grandson now gets a "beep" about every 30 seconds. How do I stop the beeping?
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Posted on Nov 18, 2008
Recovery disc windows vista
you can restore completely by doing a factory restore. you will lose all your data, however, so you should backup your important data. i found these steps
\1) Hold down the power button for 10 seconds to switch off your machine. 2) Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on your notebook. 3) When the machine Starts beeping; release the 0 key. 4) When prompted by the warning screen; select Yes to continue with the system recovery. 5) Select Recovery of Factory Default Software; click Next. 6) Select Recover to out-of-box state. Click Next again. 7) Click Next to Start recovery.
Jan 28, 2014 | Acer Aspire 4520-5582 Notebook
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
Acer aspire 7736z on button flashing can not start
!- Disconnect from Power Adapter and remove battery
2- Press Power button for 5 seconds
3- Put the battery back and start the laptop
if this doesn't work check memory and/or mainboard, or bring it to a certified troubleshooter.
good luck!
Jun 02, 2011 | Acer Computers & Internet
Hearing continuous beep sound at startup that disappears on Esc
I started having the smae problem yesterday with my Acer 1410 bought end of 2009. It started after I had stoped some suspicious process to work on start up (using msconfig). During the night I scanned the computer for virus but found nothing. Tonight I will enable those process to work on start up again and see what happens.
I will post the information tomorrow.
Aug 02, 2010 | Acer Aspire One PC Notebook
Acer Laptop Aspire 5315 Continuous Beep on Start Up
its either there is a stucked key on your keyboard or you have a bad ram (memory card).
Jun 11, 2010 | Acer Aspire 4315 Notebook
Hi, I own notebook Aspire 5570. I have problem to turn my NB on. When I push 0/I button, nothing happened. My friend checked adapter and battery, both are OK.
Please try the steps below..
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Conncet the charger (don't connect the battery yet) and try to start by pressing the power button.
Also listen carefully for any beep sounds if you hear beep sound then the rams could be defective otherwise the mother board seems to be defective.
Feb 09, 2010 | Acer Aspire 5500 5570-2609 Laptop
Machine will not start up,battery is not working but machine usually runs from the mains,machine starts up but does not make it to the bios,no beeps are detected.
Machine doesnt give beep, if the battery completely fails, you system wont start in battery and will continue to run in the main, incidcating that the battery is failing...
PLease rate this solution
Thanks
Nov 15, 2009 | Acer Aspire 5720-6661 Notebook PC
Black screen on acer aspire one .tryed download the bios from acer on usb.it works but computer clicks on and off still black sreen.no lights at all just power lights.
TRY THIS AGAIN............ i have this problem 2 days ago.. and this works on me... maybe on your's too you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios how to flash the bios: STEP 1.download the AA1 BIOS from this link: http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip 2. extract the file 3. rename the file 3309.fd to zg5ia32.fd 4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive now, start the process STEP 2 A. make sure the power cable is in B. the laptop is turned OFF C. Plug the usb stick in! STEP 3: Press and HOLD down the FN and ESC key together then press the power button, while holding the buttons release the power button and continue holding FN and ESC for about 5 seconds release the buttons and the power light will start to blink let the laptop run and DO NOT PRESS anything this can take upto 8 mins when it's done the laptop will restart. this works on me... good luck.. and i hope it will help you.....
Jun 10, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 9303, the screen remains black and 3 beep signals
2. extract the file
STEP 2
STEP 3:
Jun 07, 2009 | Acer Aspire 9300 Notebook
Acer NSK8458AN Keyboard Logo
495 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
