Question about Coby CX-TV1 5 in. Portable Television
Thin white horizontal line center of screen!
Hi, need some help please...Almost complete black screen, only one thin bright horizontal line in the middle. I already cheched some capacitors and resistances in the vertical output, all seems fine. Any ideas? Thanks.
  • 1 more comment
  • Kenneth Dash Oct 18, 2006
    Jomaru, you've been of great help! I'll proceed with through search and keep you posted on results.
    Thanks again. God bless.
  • Anonymous Jan 09, 2008
    I have a thin horizontal line across the middle of the screen. Is there an adjustment to correct ?
  • Anonymous Mar 12, 2014
    its a 29" tv. raster is only in the middle of the screen horizontally surrounded by rgb lines.seems like a scan coil fault
    Sergeant:
  • 337 Answers
The set should have a vertical output IC,You need to change it ,maybe you can check the B+ going to it because it might have opened the safety resistor if the IC went bad.You can check for broken board too unless the set is never move from one place.Be carefull when checking voltages ,there is still high voltage,not much but can num your whole hand.
Posted on Oct 18, 2006
  • Omar Urrutia
    Omar Urrutia Oct 18, 2006
    Your rating response is important too.
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung pn51d440a5d thin black horizontal lines across complete screen,2 to 3 inches apart,replaced y sustain and y buffer pcb
These lines a are technically called as 'vertical retrace' lines. There will be thin white horizontal lines, at about 1" apart, all around the screen. Even though, you've decreased the brightness and contrast to its minimum, these line will be there. There are many reasons for this fault. If the screen voltage is more than normal, or the supply voltage to video output transistors are less than normal [due to faulty smoothing capacitor], this fault can occur. If you're sound in electronics, check this link. It has details about how to check for this fault. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 04, 2013 | Televison & Video
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
No Picture On Screen
change the 33uf 35v at the vertical filter
Thans!
Mar 10, 2009 | Televison & Video
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
Coby CX-TV1 5 in. Portable Television Logo
260 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
