I have a callor gas 10 year old 3bar heater which have not bee used for the las 8 years. Now I wanted to use,but it do not want to work.It does switch on and as soon as you release the switch if goes off. What should I do.
  • 52 Answers
For a gas appliance to work it must pass a series of tests for safety reasons. there is a flame sensor that "sees" the flame and allows the system to proceed normally. If it is blocked by dirt, insects, or whatever, the system will shut down. By your own admission the system has sat idle for a long time. find and clear the flame sensor and it will probably work. You could go to the manufacturer's website and get a diagram, showing where the sensor is located. good luck, John
Posted on Nov 07, 2008
Why is this pool heater making a very loud whistle sound after heater is fired up?
could be the fan motor or check to see if a rust hole is giving you the whistle
Aug 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
"Infinity 20" probably 8yrs old now. Recently started making a humming noise whilst in use. The noise continues 15secs or so after hot water tap has been turned off.
Sounds like the diaphram in the gas control valve which is not replacable. You would have to replace the gas control valve and I would also suggest replacing the thermocouple. However since the heater is 8 years old you may think about replacing the entire hot water heater. Depending on how much water has gone through it in these past 8 years it will probably rust out soon and then you will be dealing with a flood.
Good luck,
Marty
Nov 08, 2013 | Rinnai Water Heaters
Stihl 009 chainsaw
please provide more info about saw! Your question leaves everything from stuck in a Bee tree to out of Gas. Got your mind on you saw and left a little info out about the saw, it happens. I was put on my first one at 10 yrs old and have used one every year since, i'm 63. Lets fix that Saw!
Gillight
Jun 22, 2012 | Stihl Chainsaw 009-200T (30LP-50)
I have a GG40T06/487-246 GE SmartWater Water Heater, it is about 10 years old and now there is leak on the position of the stem of the reset button connecting to the gas valve. Any suggestions to replace...
A 10 year old water heater is at the end of its life expectancy. No sense replacing a gas valve to have the tank rust out next month. I'ld replace the whole unit. Also, install a drip pan, under it and a WAGS safety device. Any water in the pan and the WAGS will shut off he Water and Gas. If your water heater has an expansion tank near by, replace that too.
Jul 19, 2010 | General Electric GE SmartWater Household...
Hot water heater is natural gas type gas is staying on all the time burning even when water is hot it continues to burn. Not hot water tank is over 10 years old should I try to repair or just replace???
The thermostat is what is out of calibration...this is built into the gas valve. Unfortunately the part cost almost what a new tank does. My opinion is to replace.....today gas valve....another 8 years the tank...
May 09, 2010 | Heating & Cooling
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
We have a old Montgomery Ward five-hundred Glass Lined hot water heater Serial # SNN 1177204708 Model # SRM33331A Type Gas NATURAL GAS PRESS IN. W.C. Input BTUH 46,000 MAX SAFE INLET 7.0 RECOVERY GPH 38.6...
I believe I had the same problem with my water heater about 15 years ago. It started with a small leak, then the tank broke flooding the room. I think it would be be best to replace the unit. Water heaters tipically have a 8-10 year life.
Mar 11, 2009 | Montgomery Ward (223600UP) Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
