Question about Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television
Power pops off and goes to standby after running for period of time. After a while power can be turned on again. john
    Sergeant:
  • 337 Answers
The first thing to look for with symptoms like this one is loose conections,in your case you might want to tap on the set while is working to see if you make it go off, if the picture distorts in any way ,if you are familiar with tv service you can remove the back cover and try it,tap lightly in different areas to see if it reacts differently,the set needs to be on while you try this and someone else need to look at the picture while you are doing it.You can use a wooden or rubber handle escrewdriver,it should not take much to make it act up.If you are not too familiar with tv service be safe and call for assistance from a servicer,you will need to resolder the loose conection if you find them,be attentive were you tap it so when it reacts you can flip the board and check the area you were taping on.Let us know how it goes or if you need more information.
Posted on Oct 18, 2006
  • Omar Urrutia
    Omar Urrutia Oct 18, 2006
    Your rating response is also important.
My Emerson flat screen wont turn on. The standby light is on and when you turn it on the green light blinks about 6 times goes solid for a second then straight to standby again. Every 20 times or so you...
The 6 blinks are actually a error code. Go to the Emerson web site you should be able to look the code up there. Its more than likely a bad power supply. I have a friend who works on tvs and he said nine times out of ten there are popped or raised capacitors in the power supply. Hope this helps.
Jun 16, 2014 | Televison & Video
Logik TV stuck in standby
if you don't hear a click its the power over switch. on the power board it is a black box. if you have the back off turn the tv on and then out of stand by and flick the black box it will probably turn on.
Feb 25, 2014 | Televison & Video
LG 42 Plasma try's to turn on but just goes back into "stanby" ?
Check to see if you get Va and Vs voltages from the power supply. There should be some wires running to the y-sus. A couple of those wires will be labeled va and vs. Are they present? There will be a sticker stuck to the panel somewhere telling you what they should be.
Mar 26, 2010 | LG 42PC3D 42 in. Plasma Television
When i switch tv on, it shows picture for 5 seconds then goes into standby. the tv is a vistron ltm-3271e lcd
The problem is associated with the power supply that cannot run under load. The showing of picture for a brief period of time indicates that the main board, ballast, inverter and panel drive are all OK. The unit turns on but the power supply cannot sustain the power requirement of the unit and shuts down.
The usual culprit on the power supply are blown or bad capacitors. Check the power supply for such capacitors. If no apparent damage or defect is found, replace the power supply.
Nov 07, 2009 | Televison & Video
SCH-I760 wont go into standby mode
Check your Power Management settings.....
Start> Settings> System (Bottom Tabs) >Power (Icon)> Advanced (Bottom Tabs). Make sure "On Battery Power" is checked and select a time 1-5 minutes.
If your on the phone for long periods you may want to check the "Power Save" tab also. It's to the right of the advanced tab.
Firehouse16
Sep 04, 2009 | Samsung SCH-i760 Smartphone
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
TIMER/STANDBY
Indicater
Number of blinks
Supposed malfunction Condition
Self-diagnosis
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
circuit.
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
TV runs for a limited time, then goes to standby
Is the fan running ,if the fan has dirt on it clean it off with contact cleaner.Set will stop playing if fan stops.
Nov 28, 2008 | LG Televison & Video
Dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Nov 08, 2007 | Jamo DVR-50 System
Problem with Jamo DVR50
You have defective caps on the power supply pcb which needs replaced.the top of the caps will look like they have been bubbled up..change all of those that look like that.
Apr 10, 2007 | Jamo DVR-50 System
Problem with system
I have two of these units and have identical problems. Noticed that the cooling fans do not come on so suspect the amplifer is overheating and there may be a thermal sensor that shuts the unit down.
Dec 05, 2006 | Zenith XBS341 System
Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
80 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
