Question about Canon PIXMA MP830 All-In-One InkJet Printer
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
Canon MP830 was being used solely as a standalone copier. It was used to copy and enlarge 4x6 photographic prints. It was not connected to any computer. After months of normal operation, one day, for no apparent reason, it ceased copying and instead produced the error message: "Scanner is not operating correctly." The scanner is definitely unlocked. And turning the unit off for a while (and even unplugging it) as the manual suggests, did nothing whatever to resolve the problem. Which of you troubleshooting geniuses out there can solve this mysterious problem?
  • jmiglia Nov 24, 2008
    OCP displys "scanner error" and no operation is allowed
  • josephc459 Dec 08, 2008
    scanner is not working correctly?
My Canon MP830 Scanner moves about 1/4 inch each time i turn it on, but will nothing will operate. The message reads, "Turn off and Unlock scanner" every time I try to use it. It was not locked. It worked fine for the 5 years I had it, now it moves just slightly each time I turn it on until it finally gets to the right hand side, then I can hear the belt skipping on the gear before it stops with the same message to turn off and unlock scanner, even though it is never locked. Any ideas? Other then tossing it out? Thanks, Chuck.
Posted on Apr 10, 2011
The error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Posted on Nov 08, 2008
My canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Dec 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanner not working
You need to check the operator's manual. For the messages it gives, there is usually a solution for it.
Nov 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My multifunction Canon Pixma MP830 will not scan. I downloaded drivers again but scan button does nothing once "start is initiated"
Will it copy standalone?If it does.
Then it is a software problem or bad cable.
If so you need to uninstall the MP navigator and reinstall without an usb cable attached.Attach a good cable and let Windows install the correct drivers
Oct 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Feed switch & alrm light on
The MP 830 usually will give you an error code in the display. If these lights just come on and you don't hear anything moving inside and no error codes, the main logic board could be bad. A rather expensive repair. Have you tried unplugging the printer and plugging in again?
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 Error Message: Scanner is not operating correctly.
This problem sucks. It sounds like the scanner has actually gone bad. This can be a couple of things. The actual ccd unit inside the scanner, a position sensor, a motor or a wire harness.
The latter two are fairly unlikely, the first two more likely. Most probable is the CCD unit. I don't think Canon sells it as a separate piece, but it comes inside a replacement scanner assembly. These complete scanner units are expensive. You'll have to check with your local Canon shop to see what they cost.
Nov 06, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Scanner is not operating correctly...
You have to download MP Navigator if you want to scan
May 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cannot copy
i cannot copy using my canon copier
Jan 26, 2008 | Canon PIXMA™ MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,010 people viewed this question
old marine
old marine
