Question about Sony FD Trinitron WEGA KD-32FS130 32" TV
Sony Wega hi. we purchased a sony wega tv less than a year ago and the tv when we turn it on flashes a red light 5 times. is there something that we could do to fix this problem ourselves? or are we going to have to call someone to come and fix it? please help thanks marcie
    Scholar:
  • 68 Answers
Hi Marcie, It sound as though the Line timebase has packed up, and the start up circuit is trying 5 times, and fails. A Service engineer sounds a must. You could unplug the TV and look inside to see if anything is obvious such as burning or a blown fuse and then present your problem again with more details.
Posted on Oct 19, 2006
    Sergeant:
  • 337 Answers
Hi Marcie,If you are familiar with tv service We can give you some ideas but that will mean opening the back and checking volts and possibly bad components,if you are not too famiiar I would suggest you to play it safe and seek the assistance of a professional.
Posted on Oct 18, 2006
  • Omar Urrutia
    Omar Urrutia Oct 18, 2006
    Your rating response is also important.
SOURCE:
The power/standby indicator is flashing a red light and my tv will not turn on.
Flashing of the led light indicates an error code, count how many times it will blink to determine where the fault came from.
Jdvillanueva
Jun 30, 2011 | Sony Grand WEGA KF50WE610 50" Rear...
Picture will come on and then go off after a couple minutes
This usually means the Lamp is failing. Replacing the Lamp usually fixes it. I would only use a Sony Replacement.
You can order one from Sony at 1800-222-SONY or you may be able to pick one up from a local Sony Retailer.
Skyassoc
Nov 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
TV popped and shut off red light flashes 5 times then pauses
this specific type of TVs flash their standby light if the onboard testing system sniffed out a problem
so, as if your TV is trying to tell you "i have a problem and i need to be serviced"
i hope it goes well for you
:D
Aug 30, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Sep 04, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Dead sony
The $1200 was for the lcd engine not the lamp. You should change the lamp. The buzz is the power supply trying to light the lamp.
Apr 25, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony dead !!!!
Jedi,
Sounds like lamp and driver need to be replaced again... Lamp is Sony p/n# A-1052-675-B and the driver p/n# 1-468-798-14
Bill
Apr 24, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Apr 20, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony FD Trinitron WEGA KD-32FS130 32" TV Logo
56 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
