Question about Kodak I620 SHTFEDSCAN Path-Through Scanner
I620 scanner Scanned images are streaked - particularly when scanning a sheet of text on a colored sheet of paper. All available parts have been cleaned without any difference in results.
  • carocdrake Nov 19, 2008
    Thanks for the tip. I didn't have a calibration target, so tried a plain white sheet of paper, scanned landscape. It seemed to clear up the problem.
  • Andre Velez
    Andre Velez Mar 12, 2012
    We buy, sell and trade; new, used and refurbished scanners. Call me about the Kodak i620. Andre 855-420-8273
  • 490 Answers
Is the scanner scanning normally otherwise? Try scanning a printed matter with white background and if it is okay, then the streaking may be because of excess brightness chosen. Check if the paper movement is at constant speed. If it is smooth paper, it may slip and the same area may scanned again, appearing like a streak.
S. Moha, Chennai
Posted on Nov 19, 2008
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
Black line on scans with neat receipts mobile scanner
Multiple lines appeared in every scan right after scanning a document from a credit card company that had those nasty adhesive strips used to attach credit cards.
First, I scanned multiple full pages to see if the problem would clear itself. After about 6 pages, I was able to identify the specific areas where the lines occurred on a document.
Next, I sprayed a tiny bit of glass cleaner (I used Sparkle glass cleaner, but I suspect any brand would work) onto an 8.5x11 sheet of plain paper in the area where the black lines appeared. NOTE: DO NOT SOAK THE PAPER, just get it damp.
Finally, I ran the dampened paper through the scanner. After each run, I would compare the result to the prior scan. As each streak was removed, I used a different piece of paper wetting only to address the remaining streaks.
After only a few runs, the streaks were gone (in my case).
Hope this helps!
May 14, 2012 | NEAT Receipts Mobile Scanner
Scanner produces streaks
It's possible that the black lines you're experiencing are an internal image adjustment issue with the scanner itself. If the scanner glass is otherwise clean, try going to the Canon DR2050/2080 utilities installed as part of the set up of your scanner and running the Adjustment Tool - it asks you to place the "adjustment paper" in the scanner. The term, "adjustment paper," appears to mean anything which has an image or text on it. Be sure you clean the scanner first before running this utility. It will have you put the "adjustment paper" through twice, and that in turn should remove the black lines in your scans, as long as there is no dust on the scanner glass. Office Depot sells cleaner sheets for laser and inkjet printers which also work on faxes and scanners and which will clean the glass for you.
Jun 29, 2010 | Canon DR-2050C Path-Through Scanner
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Assuming the document going through the scanner looks normal, there are a few things to check. If you open Capture Perfect, you can adjust the contrast and brightness as well as the thresholds. Sometimes different toners react differently to the scanner...paper is a big thing too. Multi-part forms can be tricky to get the settings adjusted so you pick up enough of the text but not that on the other side. If it's still messing up, you can try and get it serviced. Ikon is nationwide and can help out.
Apr 24, 2009 | Canon DR-7580
Green streaks on scanned images
Try placing your paper at different places on the scan bed. Also if you have fluorescent lights on nearby turn them off.
Also is your driver compatiible with your OS?
Did you recnently upgrade anythin?
Feb 27, 2009 | Microtek SCANMAKER I900 Flatbed Scanner
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Kodak I620 SHTFEDSCAN Path-Through Scanner Logo
354 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
