Question about Dishwashers
Proline pdw080/pdw081s overflow protection activated Hi, my proline pdw080 has just stopped, there is power and water supply but just dose not seem to fill...!!! Any idears... is there a filter or fuse I can check pls Thanks Si
Proline overflow protection error code E4
Posted on Dec 09, 2010
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Hi I have a Simpson 7.5kg top loader machine model no 22s701E. The water keeps continually filling. I have to turn the taps off for it to stop otherwise it overflows everywhere.
Water inlet valves operate when power is supplied to them. If you turn the machine off or pull the plug and the water stops it means that the inlet valve is ok. If the water continues to run with no power to the valve then the valve is faulty..
Replacing a crook inlet valve is not a big job for a tech..
Good luck....Nomess
Aug 03, 2010 | Washing Machines
Oe error code
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludgeOR "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check wiring harness
· Check water inlet valve
· Check pressure sensor switch
· Check circuit board
Feb 20, 2010 | Kenmore Elite 45986 Front Load Washer
The washer/dryer combo dose not stop filling up with water
check the fill valve and the connections to it the problem probly lies inthere. the valve is located inside the machine where you water hooks up.
Jul 09, 2009 | Washing Machines
Water dose ot stop when washer is full. It continues to run.
If you disconnected power and water still flowed, replace the water valve. If water stopped flowing when power was disconnected, clean out tube from tub to water level switch.
Jun 07, 2009 | GE WDSR2080D Top Load Washer
Washing machine problem
"dE"
- Lid open error Lid is open during wash cycle. Close lid.
· Check lid switch
· Check unbalance switch
· Check circuit board "OE"
Apr 30, 2009 | Washing Machines
Stops and flashes OE
"OE" error stans for :------ Water overflow error.--- This happens due to :-- Water supply does not stop after sensing an overflow condition. To resolve this problem:-- Turn off household water supply to washer and unplug power cord.· Check wiring harness
my proline dishwasher wont stop filling up
Aug 21, 2008 | Dishwashers
Dishwasher
how can i camcel a cycle on a thermadore dishwasher
Aug 13, 2008 | Dishwashers
Asko 10505 overflow problem
Replace the water valve and your problem is gone.
May 26, 2008 | Washing Machines
Dishwashers Logo
494 people viewed this question
Top Dishwashers Experts
