Question about Sony Handycam DCR-TRV460 Digital Camcorder
Cannot see anything
Can play tapes. when i try to record all I see is blank screen. It records audio.
  • 10,594 Answers
Its problem with CCD Imager and this part need to be replaced.
Sony will replace this part Free of Cost as they announced a scheme for such problem in DCR-TRV460
Please click Sony CCD Support for details.
Posted on Nov 09, 2008
Play back of video recorded on a different camcorder
sir,
you must have run a dry run before recording them in blank tape
Jan 11, 2008 | Sony Handycam CCD-TRV87 Camcorder
Tip
I've been unable to play several bought VHS tapes of films, though oddly,...
Vcr's commonly get dirty heads that cause a blue or snowy screen and no sound in some cases. In my experience the rental tapes were common point of trouble especially when you consider the amount of machines that were deployed in use back in those days. Today people run into less issues because they have there own collection and put them to good use. In order to deal with some people's problems there are three approaches to cleaning heads, the first option is to use a wet tape with the provided fluid usually two or three drops will do and run it for ten to twenty seconds. The second approach is use a dry tape with same amount of time as outlined above. The third approach is get a blank store bought tape "T120 2hours" set the vcr to sp and run the tape from beginning to end, this is a good way if you want do more of a deep clean to remove difficult dirty particles that refuse give way. I find the dry tape will give less problems when cleaning and less chance of shredding and easier for people who don't like taking vcr's apart.
on Jun 02, 2011 | Televison & Video
VHS won't play correctly - no picture, muffled low voices
Several things.
Check the tape, by opening the cover, to see if the tape is damaged. Look for signs of crinkling at the edges. This is often caused by the roller being worn on one of the VCR.
If it's damaged there's not a lot you can do.
If there's no damage try taking it out of the cassette box and fitting it in a new 'good make' blank tape tape box, discard the new tape in it. Still no good?
Next step, is the tape a movie/tv made by a commercial company. Or a recording on a blank tape?
Did it ever play? (if a movie) if not suspect a pirate tape report seller to FACT.
If a blank tape, try recording on a blank section. If that doesn't work and your video will record on other blank tapes. The tape has something wrong with it.
Some video recorders will play tapes with bad problems IE bad tracking, that others refuse to play, but you will either have to find one owned by a friend or buy one with that claim.
Sep 08, 2009 | Televison & Video
Reel to reel plays audio backwards
HAVE YOU TRIED TURNING THE REELS OVER? ON SOME PANASONIC UNITS THE REELS CAN BE PLAYED IN EITHER DIRECTION BUT THE SOUND IS REVERSED IF THE REELS ARE UP SIDE DOWN. TRY TURNING THE REELS OVER AND IT SHOULD STRAIGHTEN OUT YOUR AUDIO PROBLEM AS WELL AS BOOST THE VOLUME
JAMESFWALKERJR2006@YAHOO.COM
Aug 29, 2009 | Quantegy 456 Reel-To-Reel Recording Tape...
Tape to tape recording
Just put the tape to be copied in side A while the other the blank tape in side B. Press the play in side A . Then in side B simultaneously press the "Play " and the "Record". Then it will starting to record it will automatically stop.
Good luck:
Dont forget to rate:
Jul 01, 2009 | Panasonic SC-AK18 CD Shelf System
Gr-fxm40 wont play back
Have you tried playing the tape in a regular vcr with the VHS-C adaptor?
Jun 12, 2008 | JVC GR-FXM40EK Camcorder
Will not record on a DVD R
what I would do is play the vhs tape for a bit then rewind and press the dub botton only and see what happens. if nada then insert a new blank dvd and make sure its formated.
Apr 05, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Vidio recorder when i record it wont play back what is recorded but it will play pre recorded tapes Is it campatable for LG television please model no VR550/07
If it plays back pre recorded tapes then there is nothing wrong with that section of the unit. Does it playback audio and not picture or does it not playback anything.
Also, when trying to playback a recording what is seen of the screen? Snow(black and white dots or wiggly picture?
The unit uses two separate circuits to record and playback tapes. Is any thing else connected to the unit while you are recording? If you are using anything plugged into other ports on the recorder it may not see the camera input causing it to not record anything..
Feb 03, 2008 | Dishwashers
JVC GR-DVL120 Playback
hi
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
thx.
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
138 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
