Royal copier service code
What does code C710 mean?
Thank You,
dana
  • 1,326 Answers
Royal copiers are kind of old... But I believe that a C710 means that a charge corona wire is arching out or it could be broken. The fix I use to do is to clean the Primary & the Transfer corona wires carefully and pree the reset botton and see what happen. It could be a problem wit the HVTDC, but you may fix it with just cleaning the corona wires.. Good Luck
Posted on Nov 09, 2008
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
C710 Code on Copystar 2030
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
Feb 20, 2008 | Copystar CS-2030 Copier
84 TRANSFER BELT EXHAUSTED
84 TRANSFER BELT EXHAUSTED indicates that the transfer belt is exhausted and must be replaced. A new transfer belt must be installed to clear this error message. For assistance, you can contact Lexmark technical support or your authorized service provider. Thank you for choosing Lexmark.
Aug 31, 2010 | Lexmark Optra C710 Laser Printer
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
What does C710 stand for?
GO ON LINE AND TYPE
KYOCERA COPYSTAR CS-1820 ERROR FLASHES C710
ENTER
GO ONLINE AND TYPE THE FOLLOWING INFORMATION
MANUFACTURE NAME,MAKE,MODEL SERVICE GUIDE AND DRIVERS
ROD
Feb 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Can not clear Error Code AP
You are out of toner...It means ADD POWDER
Feb 05, 2009 | Kyocera Mita KMR-1810P Laser Printer
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
May 27, 2008 | Office Equipment & Supplies
C710 Toner sensor problem
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
Feb 15, 2008 | Copystar CS-2030 Copier
KM 1505 copier machine
click cancel+start+light then release all then press cancel.... you are now in simulation control service..... press the zoom in and out so that it will display 163.... after displaying 163 press start... the machine will restart then the code will lost.. if it return there is machine problem somewhere in the fusing unit....
Dec 20, 2007 | Kyocera KM-1505 Copier
82 people viewed this question
jasbo
jasbo
