Question about Zanussi 32 in. DE6755 Dishwasher
Dishwasher not drying
About a couple of weeks ago, unloaded dishwasher, only to find everything wet. I since noticed that it sometimes seems to be on wash cycle for a long time - about 2.5 hours after I switched it on. (Unfortunately I've never sat and watched it all the way through, as I do have a life!) Occasionally it dries fine, and rest of time - I'm not sure whether it just sticks on wash for a very long time, or goes through whole cycle and then starts washing again. Any ideas ??
I've recently had the same problem. My theory (to be confirmed) is that the heating element is not working properly (in my case not at all). This may be the element itself or the control for the element. This, I think, may account for the machine running for so long - it is waiting for the water to reach operating temp before timing the wash cycle. This also explains why the dishes do not dry. I aim to investigate this theory over the weekend !!
Posted on Jun 07, 2007
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Film on dishes
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 12, 2010 | Tappan 18 in. MDR251RE Built-in Dishwasher
Dishwasher smells has a 'wet dog' smell
its the food and the steam together. its normal.
Aug 23, 2009 | GE Nautilus 24" Built-in Dishwasher
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher will not fill. Water lines have been checked and filters are clean
Flow detection shot?
Expensive one I had couple of months ago on a Bauknecht. 300 dollars. New machine at 250. Scrapped it.
Flow detector was coupled at automatic waterstop.
Beware if you have a old machine drying with hot air, most all new models use condensation leaving your dishes etc a bit bit wet :(
Apr 14, 2009 | Dishwashers
My kenmore ultrawash quitequard 3 is not cleaning or heating up
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
heatman101
ggjk
Feb 14, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Zanussi 32 in. DE6755 Dishwasher Logo
238 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
