Polaroid FLM-2632 Television
Problem for Polaroid FLM-2632 Television
Bad Cable Input
By cchino on Oct 17, 2006
I just purchased a used Polaroid 26" LCD HDTV. I went to hook up a basic cable line to the television. The Tv works and I am getting cable channels, but the problem is the picture is really fuzzy and really unclear for almost every channel. I know that standard definition won't look good with a high definition tv. I was thinking that the tuner in the tv is bad or possibly need a new VHF line. What do you think the problem is and how can I fix it? Thanks
Comments:
Oct 19, 2006
- Ok I will try to the DVD Coaxial cable to RCA. Im pretty sure all the other outputs work. I tested both composite inputs with my xbox 360. But if it is the tuner and board, How much do you think it will cost to replace? Thanks alot for a response.
Same Problem
May 22, 2009
-   i also bought an used 26" Polaroid LCD HDTV and i hooked up my basic cable straight from the wall coax to the air/cable input on the Polaroid and all the channels look extremely fuzzy. I tried different cables and it has not changed. I hooked up my ps2 to the rear audio/video input and it works just fine. My question is if my air/cable (coax) input is bad, is there a way i can get it to work using audio/video wires?-   drgd
Best Solution
posted on Oct 18, 2006
Very Helpful)
jomaru
Rank: Guru
Rating: 87%, 493 votes
Try using your RCA imput to see how the picture looks compared to the tuner picture,is possible your tuner imput is bad,make sure the conector is not loose,the overall picture should look different but not fuzzy all over,using a dvd picture thru the aux (rca)imput should show you the difference.If the conector is loose only it could be repaired but if it is solid the tuner might be bad and it will need to be replaced along with any board it might be mounted to.Let us know how it goes or if you need more information.
Comments:
Oct 18, 2006
- Your rating response is also important.
Was this helpful?
Yes
No
Popular Solutions for Polaroid FLM-2632 Television
Questions and Unsolved Problems for Polaroid FLM-2632 Television
Do you recommend Polaroid FLM-2632 Television?
Answer
Answer
v chip issue: please help! polaroid flm-2632. we moved the tv from the living room to the bed room... (More)
Answer
is a polaroid FLM 2632 compatable with PS 3
Answer
I am having problems connecting my DVD recorder to my Polaroid TV via the component connector as... (More)
Answer
polaroid 42" Flat Screen says no signal
Answer
poloroid flm15168 what is the code so my directv remote will operate the TV also?
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , MD
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
