Question about Fujitsu AMILO D-7820 Notebook
Fujitsu AMILO D-7820 PC...
My laptop fails to boot up. On switch-on the processor fan comes on and the cd drive can be heard powering up. Then there is 4 beeps at one second intervals with a 3-4 second break. Nothing else happens, no screen etc. Can anyone help? If this is a motherboard problem, where do I get one?
  • stephen bellars Oct 18, 2006
    Had motherboard out last year to repair power socket. Dont mind replacing motherboard, not sure where to get one! also not sure how to check bios settings when the thing does not give any screen indications.
    President:
  • 2,961 Answers
Can you get into the bios and check that all settings are at default, just to check a few things, also check time and date see if they are incorrect, although sounds like a mobo fault, not worth buying another board, messy project in a laptop.
Posted on Oct 17, 2006
It may be that your memory is either loose or faulty. Try re-seating and if you have 2 in there try with only one. If you still have a problem replace with the other. Can you get into setup to see cmos setting etc?
Posted on Nov 02, 2006
Laptop wont boot, no recovery disk no repair option
If you have a windows XP HOME cd you can install Windows from the cd.
Mar 24, 2010 | Fujitsu Siemens Computers & Internet
How to open the back panel of fujitsu AMILO D 7820
u can use the software herionee to change the password ...if not use the guide which is given to u with the lptp t
Feb 05, 2010 | Fujitsu AMILO D-7820 Notebook
Amilo d-7820... Sound driver failing install.
Bad, or obsolete, driver. Uninstall the one you have now and get (as in Save, not Run) the latest version directly from Fujitsu.
Oct 18, 2009 | Fujitsu AMILO D-7820 Notebook
Where the procesor is located in Amilo A7640?
The CPU is located under the heatsink/ fan assembly.
May 09, 2009 | Fujitsu AMILO D-7820 Notebook
Wireless connection
http://support.fujitsu-siemens.com/com/support/linkapplication.html?LNG=EN&ID=3815&Action=Manuals
This is the address for the manual for this model. Hope this helps!
Nov 16, 2008 | Fujitsu AMILO D-7820 Notebook
Fujitsu siemens amilo laptop
Do you have any cd's in the cd drive or any floppys in? it could also be a usb flash drive or external hard drive. If its none of those check the bios settings and see if your hard drive is in the boot order. If its still doing it after that I would say it could be a corrupted hard drive or corrupted os on the hard drive. If all else fails try to do a system recover using the recovery cd's. if that fails its a bad hard drive.
Oct 03, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Amilo d 7820
Try powering the laptop on without the battery in (AC plugged in). If it works, you need a new battery.
Dec 06, 2007 | Fujitsu AMILO D-7820 Notebook
Hp laptop
If you still have the cd set (recoovery cd's) that came with your computer insert the first disk and reboot the computer. Make sure your bios setting are set to boot from cd first. The screen will propmt you for recovery. If you do not have them you can order the recovery cd's directly from hp/compaq. they are very inexpensive.
Hope this helps you
Nov 21, 2007 | Fujitsu AMILO D-7820 Notebook
Restoring factory default settings
ser guides are here:
http://support.fujitsupc.com/CS/Portal/support.do?srch=GUIDES
I didn't see this model listed, so perhaps the number is wrong?
If you have an operating system disk, you should be able to reinstaIl  by just inserting the disk and following the prompts.
checked one model, and that seems to be the method Fujitsu uses.
Oct 23, 2007 | Fujitsu AMILO D-7820 Notebook
Amilo D 7820
Om die HDD te verander jy moet die cd-Rom uithaal (trek die clip met a pic van a lock na oop toe) en dan kan jy die cd-Rom uithaal. As jy dit doen dan kan jy die HDD sien. Vat die 4 screws uit en trek hom stadig uit. Moenie vergeet om die nuwe HDD op "master " te sit.
Oct 16, 2007 | Fujitsu AMILO D-7820 Notebook
Fujitsu AMILO D-7820 Notebook Logo
460 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
