Home | Canon | imageRUNNER 2200 Black and White Copier | Canon IRC 2880/3380 Sca...
Canon imageRUNNER 2200 Black and White Copier
Problem for Canon imageRUNNER 2200 Black and White Copier
Canon IRC 2880/3380 Scan to Email client
By hv2724 on Nov 07, 2008
We have three Canon IRC Printer Scanners that will quite happily scan to pdf and transmit the document via exchange to both internal and external recipients - problem:- the internal recipients can read the "attached image" but all external recipient get a smaller pdf file of the same name that it totally blank when opened.
If the internal recipient forwards the mail to the external recipient then the pdf is received at full size and can be read OK.
This problem arose after the SBS 2003 SP2 (with Exchange SP2) crashed and was fully reistalled with all users etc. However as we are going to transition shortly I have left the new install at SBS 2003 SP1 with exchange at SP0.
Any Ideas?
Canon is baffled as are their local reps.
John Gardner
Solution #1
posted on Nov 27, 2008
Not Rated)
totallyall
Rank: Wiz  Canon Expert
Rating: 82%, 34 votes
re install the system software , flash the machine, or clear mmi
Was this helpful?
Yes
No
Popular Solutions for Canon imageRUNNER 2200 Black
Questions and Unsolved Problems for Canon imageRUNNER 2200 Black
Do you recommend Canon imageRUNNER 2200 Black and White Copier?
Answer
Answer
Repair for our Canon MF5750
Answer
When somebody tries to send me a fax the machine beeps several times and the transaction report... (More)
Answer
I have a Canon 210s / F139800 that is connected to the local network but I cannot access the printer... (More)
Answer
My Canon imageRUNNER 2200 won't print envelopes. How can I get this function to work?
Answer
It displays screen to turn off and back on. Error code E00012-002 is there anything i can do to fix... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon imageRUNNER 2200 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1506
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
