Question about Refrigerators
WATER LEAK IN FREEZER POOLING AT BOTTOM & FREEZING THEN MELTING
Frigidaire FRS26ZSHB2 side-by-side refrigerator/freezer has water pooling in bottom of freezer which then freezes, later melts and drips out onto floor. What is the problem?
  • 1 more comment
  • irishscott Dec 15, 2008
    I have the exact same problem and am looking for any help. I have the freezer taken apart, but have no idea how to fix this.
  • james3468 Dec 22, 2008
    Same issue here. In the back it looked like there was ice backed up behind the back wall.
  • ddixon123 Feb 08, 2009
    It appears the water is leaking from the ice-maker, running down the back of the freezer.  Every 2-3 weeks enough water builds up around the fan blades above the condenser/defrosting coils, that it starts making the grinding noise as the fan beats the ice - so we have to defrost the freezer, take all panels off the back, dry everything, etc.
The problem was indeed a clogged frost water drain. I had to pull the frig out from the wall (found an incredible amount of dust accummulation in the alcove), then remove the vertical metal and horizontal cardboard covers to expose the drain catchpan. The 1/2" rubber drain hose end was only about 1/8" above the pan pointing directly into it perpendicularly. This was not enough clearance. There was a plug (formed by dust and water) in the end of the hose that came out easily when I 'roto-rooted' it with a screwdriver. The water flowed easily after that, but I went ahead and trimmed about 3/8" off the end of the hose and pushed it back into its slot. Then I cleaned as much as I could. The prevention is to keep the area behind the frig cleaned!
Bob
Posted on Nov 08, 2008
Frigidaire GLRSF266J Side by side. Water is pooling on the fridge side in the bottom and at times seeps out the front. What do I do?
If water is on the right hand side try turning water supply off if leak stops you Have hole in water reservoir if it's on the freezer side the drain is clogged and can be cleaned out with hot water
Dec 09, 2015 | Refrigerators
Sometimes I see water under it. And the pan is always dry. Is there a clog somewhere in the line?
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps you to stop the leak,
Gene
Aug 18, 2011 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
FREEZER ON TOP
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
Why does Ice build up at the bottom of the freezer side of my Kenmore side by side refrig model # 106.54602300? Purchased in 2003 Thanks Mark
Gene
Aug 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water is collected at bottom of basket in freezer. What can I do ?
Gene
Aug 11, 2011 | Jenn-Air JSD2789GES Side by Side...
Model52552100 side by side kenmore. What cause ice build up on bottom of freezer?
Gene
Aug 10, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water pools at the bottom on the inside the freezer side of a side by side frigidaire. This frig has a water line for automated ice and dispenses water/ice on the outside. At the bottom there is a vent...
your defrost drain is plugged remove the back panel in side the freezer at the bottom you will see a metal pan with a hole in it clean around the whole and flush it with hot water a turkey baster works great for forcing hot water thru the drain and clearing what ever is plugging it
Mar 07, 2010 | Refrigerators
Water leaking from freezer.
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 12, 2008 | Frigidaire 22.6 cu. ft. Side-By-Side...
instead of ice maker heres a more common problem
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 15, 2008 | Frigidaire FRS26R4A Side by Side...
Open Questions:
Refrigerators Logo
561 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
