Question about Toshiba Satellite 1805-S204 Notebook
Troubleshooting The processes to remove cd drive and replace it with a new one, as the old drive is displaying IDE Error
  • 382 Answers
Here is a site I use for repairing Laptops.http://www.irisvista.com/tech/
Posted on Feb 02, 2009
How to remove the media drive from hp pavilion a622n
Assuming you mean the CD/DVD drive? Remove both Desktop side panels (2 screws each on back) locate drive. Remove two screws each side. Remove power and data cables - tag to make reassembly easier - or take liberal cell pictures. Drive may remove either forward or into the case depending on model. Take new and old drives next to each other, and make sure new drive is optioned the same if IDE. Put new drive in and reverse steps.
But - before doing this, what prompted the replacement? Check cables on old drive and if stuck CD, insert bent paperclip to release in old drive. Then blow out any dust. It may save $ and a lot of work.
Mar 06, 2018 | HP Computers & Internet
Tip
Solutions for exception Processing Message c0000a3 parameters 75b6bf7c 4...
Many of you might have faced issue called windows – drive not ready and a message ” exception Processing Message c0000a3 parameters 75b6bf7c 4 75b6bf7c 75b6bf7c” right below of that. It will keep disturb you every now and then even if you close this number of times This normally happens when you remove a drive like Floppy drive, CD Drive or Pen drives from its working conditions without proper instructions. You will get this error message when you remove a CD/DVD from CD/DVD drive during a process happening form CD/DVD like installing software or accessing files etc.
In that situations the programs seeking the files from the drives but its not finding there.So we are getting this error.
You can see the error below.
Here is the steps to solve the issue:
a) Simply put a CD/DVD in to the CD/DVD drive and click on Continue.
b) Open the CPU box and make sure all the data cables connected properly.Like data cable for Floppy drive and CD/DVD Drives.
c) Go to BIOS and disable the Drives which you are not using. Nowadays mostly nobody uses Floppy drive. So you can disable Floppy drive. You can disable unused IDE or SATA ports in bios.Save the settings and restart your PC, Now you will not get the annoying pop ups now.
on Jul 03, 2010 | Computers & Internet
How can i change the real time clock....
a. Click Start, type services.msc and hit ENTER.
b. Locate Windows Time.
c. Right-click and select Restart.
there can be a number of things that can halt the boot process
bios settings not right
bad or faulty leads
faulty bootmanger
make sure there are no disks in cd floppy usb drives
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter make sure your first boot device is set to your hard drive press escape then press f10 to save to cmos to restart
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope it helps
May 05, 2012 | Dell 038HRF GX150 PENTIUM-III SYSTEM BOARD
This Emachine will not boot from HD or CD. The screen only says Emachine.
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter check to make sure the first boot device is set to your hard drive
you can change it to cd if you want to install an operating system
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
make sure the CPU central processing unit has thermal paste and dust free and is securely seated
make sure your computer ram modules are securely seated with no dust in sockets also Cmos battery has charge with no dust in the socket some motherboards cmos batteries are soldered in
hope this helps
Apr 22, 2012 | eMachines T1440 PC Desktop
Hello, my name is nike. i have a problem with my hdd. when i turn on my pc it's always "primary master system disk fail" can you help me with my problem. and when i press f1 it's always...
make sure all leads that are attached to your cd/dvd have secure connections and are not faulty or just replace them they are probably old and faulty ?
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Apr 20, 2011 | Samsung (SP0411N) 40 GB Hard Drive
I replaced an old CD/DVD R/W drive with an LG GH22N550 22X Internal SATA Super Multi DVD drive. The old drive was an IDE, I believe. After installing the new drive, the system wouldn't boot. It kept...
Look on the back of the old drive to check the jumper settings (master/slave) and set the new drive exactly the same. If that doesn't work, you may have to connect the drive to a different IDE connection on the motherboard... Also, check the BIOS settings for your IDE drives and make sure the one for the CD is set to AUTO or CD-ROM.
Oct 25, 2010 | LG CD/DVD-ROM Drives (DRGDR8163BI) Burner
I HAVE A DVD RECORDER VCR COMBO,THE DVD PLAYER NO LONGER WORKS. CAN I REPLACE THE DVD MYSELF OR CAN I GET IT REPAIRED?
You can replace the drive yourself.
This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer. (some with fancy clips you can change from the old unit to the new one)
You simply remove the tray and face plate on the new drive, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap IDE DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Mar 01, 2010 | Televison & Video
I have a Philips DVD 751 DVD/vidio cd/dvd player and it will not load discs. It spits them out right away. The problem started with a disc error, don't remember what that error and can't check becasue I...
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
Feb 27, 2010 | Philips DVD751AT DVD Player
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
Change CDROM on Toshiba 2805 -s 202
IDE 1 is the CDRom (or any optical device attached). IDE 0 (zero) is the Hard drive. So this message is telling you there is a problem with the DVD/CD-Rom, that has halted the boot process. Now you have no choice but to go to BIOS (read startup screen to find the procedure, usually DEL, F2, or F12 keys) and see if the problem can be corrected there (or if not, disable the drive, save change, and try rebooting again). If this is not possible, then you might try booting from an external device (floppy, CD, USB etc) if your system allows that (and if you have the boot software/media). Otherwise, you must remove the drive, in order to regain your desktop (pass the halt stage in boot process). Here is how to remove the CD:
Underneath the laptop, there will be a screw about 4 inches in, on a centyer line direct from the DVD/CD tray panel. Remove this screw. Insert a pin or paper clip (carefully, and STRAIGHT in!) to the small hole next to the CD tray release button. This opens the tray manually. Pull it out to the full open position, then GENTLY pull further, and the whole drive will release from the laptop.
Once you have reached the desktop, you should try to remove the previous driver if possible, via start menu/settings/control panel/system (or r-click my computer and select properties). In system control panel, there is a hardware settings tab. Here you can remove or disable hardware. Try adding a "generic CD-Rom", so the DVD might get past boot process when you reinstall it (later, below).
Now, try to start the laptop without DVD/CD. If it starts normally, your driver change was incompatible, or possibly, in the process of changes you did something that impaired the drive or its ROM (or perhaps needs to be cleaned).
Now try reinstalling the CD Rom drive (no screws yet, just insert fully). If you are still at the same halt, you have cut yourself out of using this CD, unless perhaps tou can reboot with a windows CD while the drive is installed, and let windows detect and install a PROPER driver.
If that is not possible, you need another DVD/CD drive. You can also buy a replacement or cheap older model for testing system at any legitimate advanced PC shop, or many used computer parts stores. Try the drive before you buy, just slide in and mount a CD/DVD. (you may have a special adapter that must be removed from the old OEM drive and attached to new one, and the tray cover may need to be switched to allow the CD to close for testing)
Regardless of the outcome of any of the above, please post your results, and the complete text of the black boot screen here, so I can analyze the problem -or any other possibilities that may be indicated by the post dialog.
Mar 05, 2008 | Toshiba Satellite 2805-S202 Notebook
Toshiba Satellite 1805-S204 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
