Question about Sony KP-57WS500 57" Rear Projection Television
Sony kp-57ws500 light blinks 8 times
Well i replaced the resistors and they burned again whats you best bet tube or d board
  • brian mccarty Nov 07, 2008
    i have been trying to find the tube called sony they dont have it anymore and have look online and can not find it do you know who might have one
  • 10,594 Answers
Tube, that's what I was saying before.
Posted on Nov 07, 2008
  • Shahid Electronics
    Shahid Electronics Nov 07, 2008
    You need Blue Tuber under following part number...
    8-733-647-15 CRT 07MVC41(B)-L(FL) (KP-57WS500 ONLY)
    but its not available or I could not find any place.
I have a 2002 Sony KP-57WS500 that occasionly (randomly?) flashes red lines and then goes to a full screen red while giving an electrical "cracking" sound before shutting down. Once shut down,...
Seems like your RED CRT is shorting out or failing. Do you notice any other colors besides just red having problems? The blinking of the red light eight times is a High voltage error. It could be your D board but I'm thinking it is more likely the red crt is probably shorting out.
Mar 08, 2011 | Sony KP-57WS500 57" Rear Projection...
Screen turns green and small red light on front flashes 8 times
to me this is pointing towrd a bad (possibly shorted)green crt tube. howerver other possiblilities could be bad hig voltage distribution block(g2) 8 flashing means high voltage error. or an error on the d cuircit board error
Oct 09, 2010 | Sony KP-57WS500 57" Rear Projection...
With sound but no video only raster with vertical lines
The resistor (r9335) on the blue crt base board is open and burned thats why the 200v is missing. replacing the resistor will solve the problem. cheers!
Apr 08, 2009 | Sony KP-FX532M91 TV
SONY KP-FX432m91 PROJECTION TV 10 BLINKS OF STBY LT
tyoe in google bar understanding sony blinking codes.
Feb 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony 57ws500
Ok, here are details of all resistors ...
R7324= 1k 1/2w
R7326= 220 ohms 1/2w
R7301= 10 ohms 1/4w
Need further help, let me know please.
Nov 06, 2008 | Sony KP-57WS500 57" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
The tv goes on stand by mode by itself. My 57' sony does not turn on but remains in stand by mode. Blinks 9x then stops, then starts all over again. What needs to be done?
9 blink in your Sony KP-57WS500 shows error / problem in Audio section.
1= +19 volts &-19 volts are shorted by any reason on A and B board.
2= IC708 is faulty on A board
3= PS701 & PS702 (fuse) are open on A board.
Above are possible reasons of 9 blinks.
If you have electronics knowledge and have tv repair skills then check as per above info. otherwise I recommend get help of TV tech person or contact nearest Sony service center.
Thank you.
Oct 05, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500
did you check the huge resistors in front of the heat sinks? If so the next items to check would be the velocity boards that are attached to the convergence yokes on each tube the resistors on those boards could be open as well.
Jun 22, 2008 | Sony KP-57WS500 57" Rear Projection...
Blinking standby light (6 times)
Sounds like the blue CRT is failing. You might be able to squeeze a little more life out of it by adjusting the blue screen control, but it will fail again very soon and the blue tube will need replaced.
Feb 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
you can get coolant at a electronics part store if there is one in your area, does that tv have a g-bd on the left side looking from the back?  that also might be your 7- blink problem
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
114 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
