Question about MPC Computers Envision EN 7100s 17 in. Flat Panel LCD Monitor
EN-7100si Hi my problem is that my lcd will light up for half a second the go almost completely black. If its connected to the graphics card the i can see desk top or internet whatever i am currently on but only for half a second and if its not connected to the cpu then I see the Cable Not Connected announcement. If I press the power off then on again I get another half second. Only time i can see anythigh is for that first second when it powers on. I have tried connecting it to other 2 other computers and have the same problem.
  • 1 more comment
  • ottlaw2 Dec 03, 2007
    SAME problem. 3 year warranty exoired 3 months before monitor died.
  • Anonymous Dec 03, 2007
  • Anonymous Dec 17, 2007
    The exact same problem,and i can take a flashlight and shine it on the screen at an angle and see the icons and the desktop backgroun
    Problem Solver:
  • 5 Answers
Yikes!!!
NO.. Do not replace the LCD panel, nor the chip that controls the backlight (there is no such chip anyway), nor the backlights themselves, as none of the above are broken.
There are some capacitors on the low-voltage side of the internal SMPS. One or more of them is bad. Most likely, you will be able to see bulged tops on them. Replace them with identical uF rating and same or higher voltage rating, making sure to get the polarity correct.
About the only CORRECT thing I've seen in any of the other replies to this post is that the problem is common among many LCD monitors. I've personally repaired five of them in the last three days.
Posted on Oct 23, 2008
Had exact same problem........
Pharkus was right on. Replaced the 1000uF 16V and the 470uF 16V caps next to the largest/yellow transformer. One at the top and one to the left. Works like new!!!
Thanks Pharkus!!!!
Mark
Posted on Mar 24, 2009
This problem is common between a multitude of lcd's i am pretty sure that it is either a lcd bulb problem (mini floresent) or the chip inside the monitor that corrects the amount of power the bulb gets. I have replaced bulbs for these and it has fixed this problem.
Posted on Jun 18, 2008
The LCD IS MOST LIKELY GOING TO COST YOU OVER 150 DOLLARS TO GET IT FIXED BUY A NEW ONE
Posted on Oct 01, 2007
Where can i get a windows 7 64 bit driver for en-7100si
dear you can download that drivers from this site and enjoy http://www.helpdrivers.com/monitors/Envision/EN-7100si/
Oct 20, 2014 | Envision Computers & Internet
How do I get a evga gt 610 2gb graphics card to work with my pc?
If you have a black screen with a blinking DOS/text-mode cursor, and you're sure you disabled the integrated graphics, the card is bad or your power supply is not delivering enough electricity on the 12v line to start up the graphics card BIOS.
To check if it's your power supply, simply disconnect your DVD and hard drive from power, and your video card will have enough 12v juice. (the GT610 needs more than half of the power on the 12v line that the stockPavilion P6-2330 can supply). If disconnecting your drives fixes your issue, you will need to buy a better power supply to use them at the same time. One with 15-20A on the 12v line is ideal, a good price is $50 or less.
If it still doesn't display anything besides a blinking text cursor when your drives aren't connected, try re-seating the graphics card and make sure all the pins are completely connected, if this doesn't solve your issue, the video card is most likely bad, just exchange it.
If you have a black screen with a mouse, your new card is probably being used as a 2nd desktop. To confirm, just connect your monitor to your integrated graphics; if you get a picture, just set your new card to be the primary desktop.
Dec 01, 2013 | HP Pavilion p6-2330 Desktop PC
My screen is flickering. The laptop is only a month and a half old. Originally only happened temporarily when it came out of sleep. Now happens consistently. Also happens now when I move the computer...
hi
your inverter card may have come loose from the connection -- or this could also be a result of bad connection with the LCD itself -- anoither possibility is bad video card
have you tried updating the Windows OS as well a sthe Lenovo drivers for video ?
go to this Lenovo site , update the video graphics drivers
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=288288
Aug 15, 2011 | Lenovo IdeaPad Y460p Laptop Computer -...
I have a en-7100si monitor. It has been working just fine until this morning and it does not power up. when I turn it off and then on, it will flash the screen picture then go black. Can you help? ...
HI there,
I fix many lcd screens
i can tell you that its usually a result of the capacitors going bad.
If you dont mind taking the screen apart you can fix it yourself for around £3 providing you have a soldering iron and supplies.
If not you can buy a cheap iron for about £10 from maplin or similar shop.
Any caps that look buldged have blown and should be replaced.
It seems to be a common problem with your screen, you can find more information at the following link
http://www.ehow.com/how_5086953_repair-flatpanel-lcd-computer-monitor.html
Hope this helps
please rate
thanks
Apr 15, 2011 | Envision Computers & Internet
TV-out problem on my geforce fx6600 graphics card
boot into safe mode (F8) and uninstall the video card.
Dec 09, 2009 | Nvidia GeForce FX6600 512MB PCI Express...
CCFL OK but no display
LCD panel. i have several Toshiba laptop with bad LCD.
Nov 04, 2009 | Toshiba Satellite LP154W01 Notebook
Acer screen is black or blurry
If you've connected an external monitor to your computer and the image is coming up fine then that means your video card on the motherboard is good.
The only other parts it could be is the LCD Flex cable that connects to the LCD screen to the motherboard, the LCD Inverter that powers the LCD screen or the LCD screen itself. Usually you can find a used screen that is complete with all those components on ebay.
Jul 30, 2009 | Acer Computers & Internet
When I power up my PC and monitor, the screen comes on for a couple of seconds, then it goes black
this happens with a few monitors and some graphics cards. if you connect your monitor through a DVI cable, try connecting it through an analog cable. if possible change your graphics card, that should solve it completely.
Jul 01, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
MPC Computers Envision EN 7100s 17 in. Flat Panel LCD Monitor Logo
547 people viewed this question
Top MPC Computers Computers & Internet Experts
Paul Bade
Muggs01
Muggs01
Mark Gough
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
