Question about Indesit Washing Machines
The washing machine turns on;but the dial keeps turning round on its own,even though i have removed a blockageof a 1p coin and a small hair bobble.any advice please?
  • 135 Answers
Your pump may have been damaged and could need replacing.First try resetting on all three black dots and then try just a spin to see if resolved
Posted on Nov 07, 2008
My hotpoint Aquarius wmf740 washer dial is just spinning is there an easy fix
yes
its in error mode
its trying to get back to where the error was last
drain the machine from the filter
power off the mains
hold in the power on button
and turn on the mains
it will reset
the machine does a simple self check when it turns on
so a faulty pump will cause this
usually its a faulty pump housing is leaking water
or blocked up
so the pump cant move
when you turn it on it spins the pump motor a few turns and detects its running
so you may need to remove the filter round cover screw
and its tray
and check the pump viens move
may be some hair clip or clothes wires stuck in it or a coin etc
it should go to then where it left off
i would at this point stop it with the button
move the selector to drain
and let it drain and end
or to short spin
if it spins aok and ends
then you can just go for it with a load
if it fails to short spin and drain something else is wrong
prob electronic
Dec 10, 2014 | Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Oct 30, 2013 | Beko Washing Machines
Washing machine will not start
we had a very similar problem, our machine is only 12 months old and the filter at the bottom front of the machine has a small fan in it the filter was blocked with a coin blocking the fan from turning after reomoving the coin the fan was able to turn and the machine functioned correctly. hope this helps. tony
Jul 19, 2012 | Tricity Bendix AW1000W Front Load Washer
My siemens washing machine S14.39 keeps stopping at display F:18
Hi
It is your pump that is failing / bolked with hair and treds behind the impeller. The pump is not the best design as ther can enter smal treds and hair behind the impeller into the paking ring (seal). There is only one sollution that help - change the pump. Can be don from the fron of the mashine. Only one screw on the right side has to be removed to remove the plastig cover and the one screw to losen the pump.
May 18, 2010 | Washing Machines
Dial keeps spinning
I have an Ariston Margherita AL128 and the same problem happened. The dial keeps on turning and the operation does not finish at all. After skimming through the manual, it occurred to me that it could be the pump that's causing not to drain or spin anymore. Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manual once in a while, it does help! I lost mine but was able to download a copy from the net.
Feb 01, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Dial continuously turning
hiya
to reset the dial, switch the power off, then turn the dial to a dot on the selection then switch the power on, the light should flash about 3-4 times this should be it reset.
for the machine to start doing this mid cyle though usually indicates something is wrong, i would hazard a guess at the pump filter is blocked and the mahine was trying to drain at the time it started clicking.
the best thing to do is empty the machine manually by placing the outlet hose into a bucket or large dish, once empty remove the plastic kick plate on the bottom of the machine and behind this you will find the filter.
before you unscrew the filter you will need to place some towels or old cloths on the floor as there will still be water left in the pipes, remove filter and any foreign objects (possibly coins, hair clips etc) and then screw back in. job done.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 02, 2008 | Ariston Technologies Ariston AWD12 Front...
Dial keeps turning on machine
machine wont operate when dial is at rinse
Jul 17, 2008 | Hotpoint BWM12 Front Load Washer
Washing machine will not drain
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
Jun 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Programme dial again
yes thats your problem,the reason it wont unscrew is because of things caught inside ie coins gunk you will have to take out machine turn on side,there are two sometime four screws at front of machine where black dail is remove these,when machine is on its side you can acess pump from underneath,there is a black rubber hose which goes from drum to pump which is held on with a circlip remove this at pump end you will need a vicegrip,remove all gunk coins ect, refit all back to machine ,,problem solved......the reason dail was turning was because it was looking for progam to release water which it couldnt because of blockage,after tou unblock you will find that black srew on cover on front can be removed(always better to check for blockages every few weeks hopes this helps
Dec 18, 2007 | Hotpoint BWM12 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
